Webcast-Catalyst9k
Connect existing network
Hi all
I am building a lab before I can move on to seperate our existing network (no VLAN, all devices in the same subnet)
I use 01 cisco router 2911 to connect 01 no-VLAN network with other VLANs network
They can work well if I point the default gateway of the PC belong to no-VLAN network to the IP address that I configure for Router interface.
But if I use another default gateway, they cannot work.
Because our existing no-VLAN network have a different gateway, I need to keep the existing configuration (no change). How can I configure the router to receive all packets from the existing no-VLAN net work? (without changing the default gateway of that network)
What I did:
PC  <---->   existing no-VLAN network  (gateway: 172.x.x.4)   <------>  router (ip interface G 0/1: 172.10.0.102)
If I changed gateway in PC from 172.x.x.4 to 172.10.0.102 ===> it works
but I do not want to change this gateway
Please help
Sorry, I am a little confused on the issue, but it sounds like you need to add an IP ROUTE statement. Basically telling everything to route to .102 unless it's Internet Traffic.
Sorry, I you might need to explain it a little bit better.
Re: Connect existing network
I meant that our existing network is NON-VLAN (172.x.x.x) with all users and servers in the same network.
I want to seperate users by build new networks with several VLANs.
Now I use router Cisco 2911 to connect our existing network with the new VLANs.
The problem is our existing network has it own gateway (172.x.x.4). And I configured in router Cisco another IP address (172.10.0.102) ==> I connected the existing network to this interface. Howerver, to make the existing network works, I have to change the IP default gateway for my PC from 172.x.x.4 to 172.10.0.102)
This is a lab, so in real existing network I cannot change the IP default gateway like that. I need to keep all things the same
What should I configure in the router ?
170
