connect nexus 5k to hp 3800 via vPC
As the title says, I am connecting a stack of 3800 switches to a Nexus 5K pair using a virtual Port Channel. However, the second connection never comes up, and in the one case we've had where connection 1 goes down, the second connection didn't take over. Is anyone out there doing this successfully?
Russell
             +------------+__________+------------+
             | Nexus 5K-1 |__________| Nexus 5K-2 |
             +------------+   vPC    +------------+
                  c|                         |
                  o|                         |
                  n|                         |
                  n|                         |c
                   |      +------------+     |o
                  1+------| HP 3800-1  |     |n
                          +------------+     |n
                               |S|           |
                               |T|           |2
                               |A|           |
                               |C|           |
                               |K|           |
                         | HP 3800-5  |------+
HMMB5K-1# sh run int po101
!Command: show running-config interface port-channel101
!Time: Thu Mar 13 19:24:06 2014
version 5.0(2)N2(1)
  description Garden Level North
  switchport mode trunk
  vpc 101
  logging event port link-status
  logging event port trunk-status
  speed 10000
HMMB5K-1# sh vpc 101
vPC status
id     Port        Status Consistency Reason                     Active vlans
101    Po101       up     success     success                    1-13,18,20-
        21,24-32,35
        -37,42,45,5
        0,54,60,70,
        80,91,9....
HMMB5K-2# sh run int po101
!Time: Thu Mar 13 19:03:00 2014
version 5.0(2)N2(1)
  vpc 101
  speed 10000
HMMB5K-2# sh vpc 101
vPC status
101    Po101       down*  success     success                    -
HP# sh trunk
 Load Balancing Method: L3-based (Default), L2-based if non-IP traffic
  Port   | Name                             Type      | Group  Type
  1/49   | HMMB5K-1.1-1                     SFP+SR    | Trk1   LACP
  3/49   | HMMB5K-2.1-1                     SFP+SR    | Trk1   LACP
HP# sh int br | i Trk
                         | Intrusion                           MDI  Flow Bcast
  Port         Type      | Alert     Enabled Status Mode       Mode Ctrl Limit
  1/49-Trk1    SFP+SR    | No        Yes     Up     10GigFD    NA   off  0
  3/49-Trk1    SFP+SR    | No        Yes     Down   10GigFD         off  0
Let me know if any other show commands would help.
Hall of Fame Super Blue
Can you from the Nexus with
Can you from the Nexus with the port channel that is down -
1) specify which ports make up the port channel
2) post a "sh vpc" from that switch
Jon
interface Ethernet1/1
  channel-group 101 mode active
  vpc 101
  speed 10000
HMMB5K-2# sh vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 1
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
Configuration consistency status: success
Per-vlan consistency status     : success
Type-2 consistency status       : success
vPC role                        : secondary
Number of vPCs configured       : 4
Peer Gateway                    : Disabled
Dual-active excluded VLANs      : -
Graceful Consistency Check      : Enabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po10   up     1-13,18,20-21,24-32,35-37,42,45,50,54,60,70,80,91,
                   98,111-116,121-125,131-132,141,181-183,189,191,195
                   ,201,206-216,221-225,241-242,251,270,277,300,320-3
                   21,401-403,405,420-422,424-427,499-503,510-513,554
                   ,570-571,575,700-702,704,920
vPC status
100    Po100       up     success     success                    1-13,18,20-
        21,24-32,35
        -37,42,45,5
        0,54,60,70,
        80,91,9....
102    Po102       down*  success     success                    -
186    Po186       down*  success     success                    -
Russell
RussellSorry, i thought the
Russell
Sorry, i thought the "sh vpc" would also show the member ports not just the port channel interface.
Can you post -
"sh vpc consistency-parameters interface ethernet 1/1"
Jon
fails on physical interface,
fails on physical interface, but here it is on the port-channel:
HMMB5K-2# sh vpc consistency-parameters int po101
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
Shut Lan                    1     No                     No
STP Port Type               1     Default                Default
STP Port Guard              1     None                   None
STP MST Simulate PVST       1     Default                Default
lag-id                      1     -                      [(188b,
                                                         38-ea-a7-71-18-8b,
                                                         232, 0, 0), (7f9b,
                                                         0-23-4-ee-be-1, 8065,
                                                         0, 0)]
mode                        1     -                      active
Speed                       1     -                      10 Gb/s
Duplex                      1     -                      full
Port Mode                   1     -                      trunk
Native Vlan                 1     -                      1
MTU                         1     -                      1500
Allowed VLANs               -     1-3967,4048-4093       1-3967,4048-4093
Local suspended VLANs       -     -                      -
HMMB5K-2# sh vpc consistency-parameters int e1/1
ERROR: Unsupported interface type for VPC  consistency parameter info
HMMB5K-1#  sh vpc consistency-parameters int po101
    Legend:
Shut Lan                    1     No                     No
lag-id                      1     [(188b,                -
                                  38-ea-a7-71-18-8b,
                                  232, 0, 0), (7f9b,
                                  0, 0)]
mode                        1     active                 -
Speed                       1     10 Gb/s                -
Duplex                      1     full                   -
Port Mode                   1     trunk                  -
Native Vlan                 1     1                      -
MTU                         1     1500                   -
HMMB5K-1#  sh vpc consistency-parameters int e1/1
Russell
RussellI suspect the issue
Russell
I suspect the issue may be a consistency check failure at the interface level (although i could be wrong).
The port channel shows as successful for the consistency checks but that doesn't necessarily mean the physical interface passed.
The last command i asked for should have shown the consistency check status for the physical interface but it is saying it is unsupported.
So what is the equivalent physical interface on the working switch and can you run the command on that one.
Is the physical interface on the working switch from the same linecard type ?
Jon
On both 5K-1 and 5K-2, the
On both 5K-1 and 5K-2, the physical interface is E1/1, which is in port-channel 101, which is in vPC 101. The show commands of the PC and the physical interface for both nexus switches is in my previous post -
working:
not working:
Yes you did post both
Yes you did post both switches, my mistake.
What linecards are the physical ports on ?
Jon
Purple
Check the logs on the side
Check the logs on the side that did not come up ,usually it will tell you why it did not bring the second side up .  Post a show vpc consistency-parameters .   On the 3800 stack are your uplinks all bound into the same port channel ??
Hi Russell,Can you post the
Hi Russell,
Can you post the output of show port-channel summary, show lacp neigh int port-ch 101, show lacp counter int port 101 and show int eth1/1?
Also do you have UDLD configured on the Nexus switches? I've seen UDLD cause issues when connecting to HP switches as the UDLD frames are simply passed through the HP switch. Perhaps also include a show udld neigh if UDLD is enabled.
829
