connect on 22 port through PAT
Cannot connect on 22 port through PAT on router. I have next schema:
In log on ASA:
In log on Router:
*Aug  6 08:54:36.602: IP: s=5.5.5.6 (GigabitEthernet0/0), d=10.10.10.254, len 60, input feature
*Aug  6 08:54:36.602:     TCP src=44763, dst=22, seq=4072024705, ack=0, win=5840 SYN, MCI Check(66), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Aug  6 08:54:36.602: FIBipv4-packet-proc: route packet from GigabitEthernet0/0 src 5.5.5.6 dst 10.10.10.254
*Aug  6 08:54:36.602: FIBfwd-proc: Default:10.10.10.254/32 recieve entry
*Aug  6 08:54:36.602: FIBipv4-packet-proc: packet routing failed
*Aug  6 08:54:36.602: IP: tableid=0, s=5.5.5.6 (GigabitEthernet0/0), d=10.10.10.254(GigabitEthernet0/0), routed via RIB
*Aug  6 08:54:36.602: IP: s=5.5.5.6 (GigabitEthernet0/0), d=10.10.10.254(GigabitEthernet0/0), len 60, rcvd 3
*Aug  6 08:54:36.602: IP: s=5.5.5.6 (GigabitEthernet0/0), d=192.168.15.254, len 60, stop process pak for forus packet
where I could be wrong?
1 REPLY
Re: connect on 22 port through PAT
ip route 0.0.0.0 0.0.0.0 10.10.10.253 solved my problem. Can anybody explain, in configuration file I have ip default-gateway 10.10.10.253(local address of ASA), ip routing is disabled on the Cisco router, I don't have access on router, but when I use ip route 0.0.0.0 0.0.0.0 10.10.10.253, access is opening.
322
