KS3
Community Member
Connect three roters by serial ports - 10.0.0.0/8
Hello.
I want to connect three routers by serial ports. I have to use IP 10.0.0.0 and mask 255.0.0.0.
I configure interfaces on routers. R1 has two interfaces with IP:
R1-S0/1/0 IP: 10.0.10.1 255.0.0.0
R2-S0/1/0 IP: 10.0.10.2 255.0.0.0
When I want to add on second interfasec serial address R2-S0/0/1 IP: 10.0.20.1 255.0.0.0
I get message "overlaps with serialport 0/1/0".
What I make incorrect?
What is correct IP's and masc?
Please help me.
Kind Regards
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: Connect three roters by serial ports - 10.0.0.0/8
You can't assign the ip from the same segment/subnet to 2 different interfaces.
So, for interface R2-S0/0/1, you need a new subnet. Example: 11.0.20.1 255.0.0.0
VIP Super Bronze
Highlighted
VIP Silver
Hello KS3 good afternoon!
Why are you using /8? you can use /30 for all your point to point conections, so you can use 10.0.0.0/30 (10.0.0.1 & 10.0.0.2) for the first point to point 10.0.0.4/30 (10.0.0.5 & 10.0.0.6) for the second and 10.0.0.8 (10.0.0.9 & 10.0.0.10) for the last one.
----Do not forget to rate useful post and/or mark the answers as a correct.----
Best Regards,
KS3
Community Member
Hello Diana.
This is my task for example exam ;-).
Thank you Reza.
115
