connect to 2 ISP using route-map
dannan lin
hi:
i have a following  scenario.
both R2 and R3 act as ISPs. and R1 as company gateway router ,R4 as normal PCs.
R2 and R3 have same loopback interfaces with ip address 5.5.5.5 /24(emulate internet)  .
requirement :
1. traffic which  is sourced from 10.10.10.0/24 must go through s0/0 at R1
2. traffic from 20.20.20.0/24 must go through s0/1 at R1
here is what i have done
R1(config)#do show ip route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
     1.0.0.0/24 is subnetted, 1 subnets
C       1.1.1.0 is directly connected, Serial0/0
     2.0.0.0/24 is subnetted, 1 subnets
C       2.2.2.0 is directly connected, Serial0/1
     3.0.0.0/24 is subnetted, 1 subnets
C       3.3.3.0 is directly connected, FastEthernet1/0
     20.0.0.0/24 is subnetted, 1 subnets
S       20.20.20.0 [1/0] via 3.3.3.3
     10.0.0.0/24 is subnetted, 1 subnets
S       10.10.10.0 [1/0] via 3.3.3.3
S*   0.0.0.0/0 is directly connected, Serial0/0
               is directly connected, Serial0/1   /* i used default route to connect to 5.5.5.5.
Access lists
R1(config)#do show access-list
Standard IP access list 1
    10 permit 10.10.10.0, wildcard bits 0.0.0.255
Standard IP access list 2
    10 permit 20.20.20.0, wildcard bits 0.0.0.255
Route-map
R1(config)#do show route
route-map ISP_R3, permit, sequence 20
  Match clauses:
    ip address (access-lists): 2
  Set clauses:
    interface Serial0/1
  Policy routing matches: 0 packets, 0 bytes
route-map ISP_R2, permit, sequence 10
  Match clauses:
    ip address (access-lists): 1
  Set clauses:
    interface Serial0/0
i applied two policies on both serial links.
interface Serial0/0
ip address 1.1.1.1 255.255.255.0
ip policy route-map ISP_R2
serial restart-delay 0
interface Serial0/1
ip address 2.2.2.2 255.255.255.0
ip policy route-map ISP_R3
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
interface FastEthernet1/0
ip address 3.3.3.1 255.255.255.0
duplex auto
speed auto
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Serial0/0
ip route 0.0.0.0 0.0.0.0 Serial0/1
ip route 10.10.10.0 255.255.255.0 3.3.3.3
ip route 20.20.20.0 255.255.255.0 3.3.3.3
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 2 permit 20.20.20.0 0.0.0.255
route-map ISP_R3 permit 20
match ip address 2
set interface Serial0/1
route-map ISP_R2 permit 10
match ip address 1
set interface Serial0/0
i have no ideas what's wrong with this setup. the route-map did not work.
below is trace route output
R4(config)#do trace 5.5.5.5 source 20.20.20.20
Tracing the route to 5.5.5.5
  1 3.3.3.1 36 msec 20 msec 24 msec
  2 2.2.2.22 48 msec
*Mar  1 01:35:35.403: ICMP: time exceeded rcvd from 3.3.3.1
*Mar  1 01:35:35.427: ICMP: time exceeded rcvd from 3.3.3.1
*Mar  1 01:35:35.455: ICMP: time exceeded rcvd from 3.3.3.1
*Mar  1 01:35:35.503: ICMP: dst (20.20.20.20) port unreachable rcv from 2.2.2.22 *  48 msec
R4(config)#
*Mar  1 01:35:38.551: ICMP: dst (20.20.20.20) port unreachable rcv from 2.2.2.22
R4(config)#do trace 5.5.5.5 source 10.10.10.10
  1 3.3.3.1 52 msec 24 msec 20 msec
  2 2.2.2.22 48 msec
*Mar  1 01:37:17.351: ICMP: time exceeded rcvd from 3.3.3.1
*Mar  1 01:37:17.379: ICMP: time exceeded rcvd from 3.3.3.1
*Mar  1 01:37:17.399: ICMP: time exceeded rcvd from 3.3.3.1
*Mar  1 01:37:17.447: ICMP: dst (10.10.10.10) port unreachable rcv from 2.2.2.22 *  56 msec
ping 5.5.5.5 had no problems but why did both traffic go through 2.2.2.22 ?
i have no ideas what's wrong with this setup. the route-map just did not work.
I hope some one could help me out here.
thank you in advance.
3 Accepted Solutions
bava_ccna
You have to apply the policy in the ingress interface of R1 (i.e fa1/0) and also you don't need two different route-map for acheiving this. Match the access-list in two different sequence of the same route-map and assign a different next-hop for each matching criteria..
-HTH
bava
Hi Dannan,
route-maps are sequenced, like access lists. use the Same Name and different sequence numbers to apply different Match/Set clauses. and remeber there is an implicit Deny at the end of the route-map, just like access-lists.
plz Rate if it helped,
Soroush.
Hope it Helps!
Soroush.
No need for an empty permit clause at the end in a route-map used for PBR because the denied traffic will just simply routed based on the RIB.
Regards.
Alain.
9 Replies 9
cadet alain
the PBR policy must be applied to f0/1 interface of R3 not on the serials as it must be applied on the ingress interface of the source.
Regards.
Alain.
thanks for your quick reply, i am still  new to policy routing. if i have to apply the policy on f0/1, how am i supposed to do that? everytime i wrote an ip policy , the new one overwrote the older one.  i thought one interface can have a only one route map policy applied.
much appreciated.
Look at Bava's answer: you only need one route-map but with multiple clauses.
Regards.
Alain
Hi Dannan,
Soroush.
Hope it Helps!
Soroush.
thanks . i will try that.
Regards.
Alain.
bava_ccna
-HTH
bava
thanks for your help,i will try that later.
dannan lin
it worked, thanks.
