Connecting 2 4507
Whats the best way to connect 2 4507 switches? I need to connect 2 so that we can have redundant switches. Is there a special interface and cable that will give me very high bandwidth?
If possible could you detail the parts needed.
All posts rated.
Gavin
Re: Connecting 2 4507
may be to create a cluster
Hi Gavin.
I am not sure what modules you have in your 4507 chassis but if you have gig interface or gig modules where you can insert fiber gbics and then sue fiber cable to connect the 2 4507.
Check this link for various sups and line cards installation on 4500 chassis
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/hw_doc/index.htm
Ankur
237
