Connecting 3570 Switches to Nexus 2232 to migrate Server Subnets
Hello I am in the process of migrating our existing server farm subnets to our new Nexus server farm and I discovered something I wasn’t expecting. My intention is to migrate our existing legacy server farm which is comprised of for paired 3750 switches off of our core 6509s and onto the Nexus and connect them to the 2232s via multi gig port-channel connections, two port channels per switch stack.
NOTE this is expected to be a temporary move as next year we intend to install additional N2Ks and move servers over to these directly. But to minimize the outage/downtime it will be better to move the subnets and switchs all at once.
These connections would be grouped 1 gig connections as port channels, one from each switch into one of the two 2232s.
Problem I discovered is Cisco does not intend to have switches connected to the Nexus and it immediately disables the ports when they see BPDUs.
I found a config that does work and it does fail over from one port-channel connection to the other but with the limitation that when the original port channel comes back online it does not fail back over to the original one, an acceptable situation for us. But I am wondering if Cisco would support this design if we did experience issues down the road.
The only issue I really see is to get it to work the config is different on the two N5Ks, please see the pert config below for the connections. Both are running the same OS
augs1-ba-ar17# sh ver
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2011, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 3.5.0
  loader:    version N/A
  kickstart: version 5.0(3)N2(1)
  system:    version 5.0(3)N2(1)
  power-seq: Module 1: version v3.0
             Module 3: version v5.0
  uC:        version v1.2.0.1
  BIOS compile time:       02/03/2011
  kickstart image file is: bootflash:/n5000-uk9-kickstart.5.0.3.N2.1.bin
  kickstart compile time:  6/13/2011 6:00:00 [06/13/2011 09:43:33]
  system image file is:    bootflash:/n5000-uk9.5.0.3.N2.1.bin
  system compile time:     6/13/2011 6:00:00 [06/13/2011 11:33:42]
augs1-ba-ar17# sh run
interface Ethernet101/1/31
  description Eth101/1/31 Portchannel_31 Int 1 of 2 augs1-ba-sw90_G2-0-25
  switchport trunk allowed vlan 1,105,107
  speed 1000
  channel-group 31
interface Ethernet101/1/32
  description Eth101/1/32 Portchannel_31 Int 2 of 2 augs1-ba-sw90_G2-0-26
  speed 1000
  channel-group 31
interface port-channel31
  description Eth101/1/31-32 to augs1-ba-sw90
  switchport mode trunk
  speed 1000
augs1-ba-ar18# sh run
interface Ethernet102/1/31
  description Eth102/1/31 Port_Ch_32 Int 2 of 2 augs1-ba-sw90_G2-0-28
  speed 1000
  channel-group 32
interface Ethernet102/1/32
  description Eth102/1/31-32 to augs1-ba-sw90
  speed 1000
  channel-group 32
interface port-channel32
THIS IS THE SWITCH CONNECTED to the NEXUS
Augs1-ba-sw90
interface GigabitEthernet2/0/25
description PC1 augs1-ba-ar17_E1-9
channel-group 1 mode on
interface GigabitEthernet2/0/26
description PC1 augs1-ba-ar17_E1-10
interface GigabitEthernet2/0/27
description PC2 augs1-ba-ar18_E1-9
channel-group 2 mode on
interface GigabitEthernet2/0/28
description PC2 augs1-ba-ar18_E1-10
interface Port-channel1
spanning-tree guard none
interface Port-channel2
switchport backup interface Po1
Note no switchport mode trunk on the ports on the AR17 box.  When I attempt to add it I I have to first remove the channel-gr command and then when I go to add channel-gr command back I get an error saying the port is not compatible??  Any thoughts on why this is on AR17 and not on AR18?
augs1-ba-ar17(config)# int eth101/1/31
augs1-ba-ar17(config-if)# switchport mode trunk
% Invalid command at '^' marker.
augs1-ba-ar17(config-if)# switchport ?
  host     Set port host
  monitor  Monitor session related traffic
augs1-ba-ar17(config-if)# no channe-gr 31
augs1-ba-ar17(config-if)# no channel-group 31
  <CR>
  access       Set access mode characteristics of the interface
  autostate    Include or exclude this port from vlan link up calculation
  block        Block specified outbound traffic for all VLANs
  description  Enter description of maximum 80 characters
  host         Set port host
  mode         Enter the port mode
  monitor      Configures an interface as span-destination
  priority     CoS Priority parameter
  trunk        Configure trunking parameters on an interface
  voice        Set voice mode characterestics of the interface
augs1-ba-ar17(config-if)# channel-gr 31
command failed: port not compatible [port mode]
Any thoughts as to why the config has to be different from one 5548 to the other?
Do you think Cisco TAC will support this setup if I call in for an issue?
~ Phil
Bronze
Hi Phil,
We've not had any problems linking 3750s (Specifically 3750-E and 3750-X) to Nexus via PVCs and Portchannels, however we always link them to the 5K directly rather than to one of the FEX's
Is it possible for you to connect to the main NEXUS chassis (5K/7K etc) instead of a fabric extender?
Cheers,
Nick
Hi Nick thanks for the response, so first as far as my config goes do you see where one has the switchport trunk command on the physical interfaces and the other N5K does not?  Any idea on that?
As for plugging directly into the N5K that is what I first attempted but when I would look at the interface it did not recognize the SFP.  I am using regular 1G SFPs adn the N5K does not recognize them, the port would not come up so I tried it on the 2232 and it worked there but with the wierd difference in configuration.
~ Phil
Bronze
Hi Phil,
Several ports on the 5K can only take SFP+ modules, while some can take both SFP and SFP+. I don't remember offhand which are which, but that is likely the cause of that particular issue.
I'd imagine that in order to get the port channel working properly you need to default the config on the interfaces you want to add, then add them to the port channel, then set the port channel to be a trunk and see if that works.
I'd also advise against using etherchannel set ON, and would use LACP instead (mode active) as this gives you better protection against misconfiguration, and more troubleshooting options when something doesn't work, but that is just my personal preference.
Nick
Bronze
Hi Again,
Just spoke to my Colleague who is more NEXUS that I and he said that ports 1-20 on the Nexus 5020 can take SFP.  I'm not sure if that helps at all...
Nick
Hi Nick thanks a lot, that could be my problem, I am using standard SFPs and I was trying to use the LAST ports for my testing so it would be obvious they were for testing.  I will give it another go in a closer port.
Also, As for the channel group ON setting.  I am pretty sure that was the only way I could get it to work with a 3750 switch, I thought I saw that in another thread somewhere to use that config and it came up.
Ill re-visit it, unfortunatly we are in a change freeze till the end of the year so I cant play.
~ Phil
953
