Community Member
Connecting 3750 stacks help please?
I've been asking about connecting two stacks and have finally got to the stage where I'm ready to go but was hoping someone could have a quick look at this to see if I'm missing anything?
Stack1 is our existing production stack and cannot have any downtime
Stack2 currently only contains one 3750 Catalyst switch, this will increase over time
I have created an etherchannel port on both stacks ready to link them.  Stack 1 is the VTP server and stack 2 is set to VTP client.  Stack 1 has a loopback address of 10.130.0.1 although when the stacks are connected I will be changing this to use HSRP with the .1 address as the standby address.  Below is the relevant config of the switches, are the OSPF settings valid?
Anyway, if anyone sees anything blatantly wrong or if there is something else I neeed to look at please let me know.  Apologies if this is very basic but you have to start somewhere don't you .  I'm just terrrified of joining the stacks and bringing everything down.
Stack 1
interface Loopback0
ip address 10.130.0.1 255.255.255.255
router ospf 1
router-id 10.130.0.1
log-adjacency-changes
redistribute static subnets route-map static2ospf
network 10.130.0.0 0.0.255.255 area 130
interface Port-channel30
description EtherChannel to Stack2
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/0/25
description Po30 member stack 2 etherchannel
speed 1000
mls qos trust dscp
channel-group 30 mode on
interface GigabitEthernet1/0/26
speed 1000
mls qos trust dscp
STACK1#sh etherchannel summary
Group  Port-channel  Protocol    Ports
30     Po30(SD)         -        Gi1/0/25(D) Gi1/0/26(D)
STACK1#sh vtp status
VTP Version                     : running VTP1 (VTP2 capable)
Configuration Revision          : 24
Maximum VLANs supported locally : 1005
Number of existing VLANs        : 21
VTP Operating Mode              : Server
VTP Domain Name                 : stacks
VTP Pruning Mode                : Disabled
VTP V2 Mode                     : Disabled
VTP Traps Generation            : Disabled
MD5 digest                      : 0x53 0xCF 0xFB 0x10 0x0F 0xAE 0x7B 0x6C
Configuration last modified by 10.130.1.1 at 6-16-10 12:35:49
Local updater ID is 10.130.1.1 on interface Vl1 (lowest numbered VLAN interface found)
Stack 2
interface Loopback0
ip address 10.130.0.3 255.255.255.255
router ospf 1
router-id 10.130.0.3
description EtherChannel to Stack1
interface GigabitEthernet1/0/49
description Po30 member stack 1 etherchannel
speed 1000
mls qos trust dscp
interface GigabitEthernet1/0/50
speed 1000
mls qos trust dscp
Sh Etherchannel summary
30     Po30(SD)         -        Gi1/0/49(D) Gi1/0/50(D)
STACK2#sh vtp status
Configuration Revision          : 0
Number of existing VLANs        : 5
VTP Operating Mode              : Client
MD5 digest                      : 0xE3 0x08 0x2D 0xC3 0x8D 0x99 0xE1 0x5D
Configuration last modified by 0.0.0.0 at 0-0-00 00:00:00
1 ACCEPTED SOLUTION
Re: Connecting 3750 stacks help please?
When you configure spanning-tree vlan root primary on the stack 1, it
will ensure that your outage is minimal and adding the new stack will not
affect your performance. If that command is not added, there is a chance
that during the recalculation, Stack 2 assumes the root role and all your
traffic need to pass through Stack 2. When you retire Stack 1, the Stack 2
automatically assumes the role of root because it is configured as root
secondary. However, it will not completely eliminate to downtime that will
be due to spanning-tree recalculations (when adding the stack).
Hope this helps.
NT
The configuration looks good. One thing that is missing is the spanning-tree
configurations. Since stack 1 is already up and running, I would suggest
configuring it such that it retains the root position when you connect the
new stack.
"spanning-tree vlan root"
Also, remember that you will have a short down-time till the spanning-tree
converges.
Hope this helps.
NT
Community Member
Thanks NT,
If I apply the spanning-tree vlan root command to stack 1, what would the outage affect, Stack1, Stack 2 or both?
The next stage of my plan is to move some switches to stack 2 and finally retire Stack 1.  Would it be worthwhile adding the spanning-tree vlan root primary to stack1 and spanning-tree vlan root secondary to Stack 2?
Once stack 1 is retired I could change Stack2 to be primary or even remove the command?
Thanks again for your help.
Dave
edit:
I have just looked at the config on stack 1 and seen the following lines
spanning-tree mode pvst
spanning-tree portfast bpduguard default
no spanning-tree optimize bpdu transmission
spanning-tree vlan 1-2,10-13,50 priority 24576
Will this affect anything?
Hope this helps.
NT
194
