Community Member
Connecting a WLC 4400 to a 2960 POE Catalyst
                   I need some help connecting my WLC 4400 to my 2960 catalyst switch. The gigabit port
on the Catalyst switch I am using is connected to port 1 on WLC 4400. I have the port set to trunking
mode but I cannot ping the management interface IP. I also noticed the activity lights on the two interfaces
are not lit.
interface GigabitEthernet0/2
switchport mode trunk
Is there something else I need to attribute to this port?
1 ACCEPTED SOLUTION
Bronze
It is the management interface address on the native vlan?
The management interface is left untagged so if does not belong to vlan 1 the next step is to configured the native vlan on the switch interface
switch(config)#int gi0/2
switch(config-if)#switchport trunk native vlan #
Haihua
VIP Super Bronze
Is the interface in up and up mode on the 3560?
can you issue command:
sh ip int brief gi0/2
and sh int gi0/2
Is there link light (green) on port gi0/2
Community Member
Sorry to get back to you so late. Here is what I got.
Wireless#sh ip int brief gi0/2
GigabitEthernet0/2 unassigned YES unset down down
Wireless#sh ip int gi0/2
GigabitEthernet0/2 is down, line protocol is down
Inbound access list is not set
It is plugged in.
Community Member
Oh and the switch is a 2960 POE
Bronze
Haihua
Hall of Fame Super Blue
I need some help connecting my WLC 4400 to my 2960 catalyst switch. The gigabit port on the Catalyst switch I am using is connected to port 1 on WLC 4400. I have the port set to trunking mode but I cannot ping the management interface IP. I also noticed the activity lights on the two interfaces are not lit.
Make sure the WLC port is configured for LAG as well as tagged.
Community Member
After all that it was the patch cord, boy do I feel stupid. The patch was brand
new as well. Well here is how the port was setup. And I can access the WLC gui
so I am all set.
switchport trunk allowed vlan 1,10
media-type rj45
414
