Connecting Cat 4510 to 6509
What should I look out for in connecting a Cat 4510 with Sup V to a Cat 6509 with Sup720?. Thanks
Re: Connecting Cat 4510 to 6509
If there are other switches involved, Spanning Tree and/or routing issues.
HTH and please rate
Hall of Fame Super Blue
In addtion to previous post. If you are connecing at layer 2 and your are using vtp in your network you need to make sure you have setup the client/server roles correctly.
Assuming you 6509 is the vtp server you need to make sure the 4510 is in client mode with a lower configuration revision number. If you want to be sure set the 4510 to vtp transparent which will set it's revision number back to 0 and then put it into vtp client mode with the correct vtp domain name. It will then pick up the correct vlans.
Spanning-tree. Usually you would want your 6500's to be spanning-tree root and secondary but without knowing your topology it's difficult to say. You can explicity set the root and secondary and you should otherwise you might find one of your access-layer switches being root for all vlans.
If you're connecting at Layer3 less to worry about. No spanning-tree, no vtp etc. Just make sure you don't create routing loop.
Jon
No we will be connecting using Trunks and yes it is vtp.
What I am concerned about is spanning tree.
How do I make sure that the Cat4510 does not take over as spanning tree root?
We set the spanning tree root and secondary though but only on the 6509.
Thanks for your help.
Just make sure your vlans priority are higher than what is set on the 6509. Post the results from a 'sh run | inc spanning' from the 6509 and the 4510 and that will show what switch will have the priority of which vlan.
Nice catch on the VTP Jon, I'll give a couple of points for that one!
If you have explicitly set your 6500's to be root and secondary then you should be fine. Is your 4500 a new bit of kit. If so it will have the default spanning-tree priority of 32768.
You only need to check if it a switch with an existing config on it.
Jon
Its a new one.
These are the show run | i spanning
SwitcA#sh run | i spanning
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
spanning-tree uplinkfast max-update-rate 15
spanning-tree vlan 1-999 priority 8192
SwitchB#sh run | i spanning
spanning-tree vlan 1-999 priority 16834
These configs are taken from your 6500 switches yes ?.
If so they are fine and you should have no problems with the 4500. Just make sure when you connect up the 4500 that there are no "spanning-tree vlan x priority x" statements on it.
As i said by default spanning-tree will be 32768 on an unconfigured switch.
Jon
If you'r particularly asking about conflicting issues or something like that, than no, there's nothing like that. It'll be a normal configuration according to the replies above
192
