Webcast-Catalyst9k
Connecting Catalyst 4507R and Catalyst 2950 - Vlans and Trunking
I am having an issue networking a Cisco 4507R and Catalyst 2950 Series.
I have only worked with simple vlans so please forgive me. They have
the same encapsulation and everything seems fine to me but I can't ping
between them. Here are my configs
interface GigabitEthernet0/1
switchport access vlan 405
switchport trunk native vlan 405
switchport mode trunk
Catalyst 4507R
interface GigabitEthernet2/1
switchport nonegotiate
Here is what else I have
--Catalyst 4507R--
show int g2/1 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Off
Access Mode VLAN: 405 (N-1-Connect)
Trunking Native Mode VLAN: 405 (N-1-Connect)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Voice VLAN: none (Inactive)
Appliance trust: none
Surveillance#
Here is what I have for my Catalyst 2950 Series
Switchport: Enabled
Negotiation of Trunking: On
Access Mode VLAN: 405 (VLAN0405)
Trunking Native Mode VLAN: 405 (VLAN0405)
Voice VLAN: none
Protected: false
-Unknown multicast blocked: disabled
AL-SURV-L2#
The vlan 405 is in the vlan database of the Catalyst 4507R with an ip
address 192.168.122.4. It is apply to the g2/1 interface. Do I have
to create a 405 vlan with an IP address on the 2950 and apply it to the
g0/1 interface?
Any help is greatly appreciated. Thanks.
Re: Connecting Catalyst 4507R and Catalyst 2950 - Vlans and Trun
You need to create two layer-3 vlan interfaces.
Example-
switch#(config)interface vlan 405
switch#(config-if)ip address 192.168.122.4 255.255.255.0
switch#(config-if)no shut
This will allow hosts on vlan 405 to use 192.168.122.4 as a gateway.
Thanks for the reply. But can I do this when the Catalyst 2950 is a layer 2 switch?
You should do it on the 4500.
I believe I have done that. Here it is in the config of the 4507R, sorry I didn't post it earlier.
interface Vlan405
description Connection to XXXXXXXXX
Then I applied this vlan to the g2/1 on the 4507R
Purple
Is there a reason you are trunking if you are only passing vlan 405 between the boxes ????
It's vendor specific. Streaming video traffic will be going between these switches and that's the only way the vendor says it will work. Also don't I need it if I want to route other vlan traffic between the switches?
Please disregard the last paragraph. I thought I deleted it out. I realize that the Catalyst is a Layer 2 device. Sorry for the confusion. Thanks.
Bronze
Rob,
Is quite simple to understand a typical scenario. You will have the 4507 switch as the core of your network. On this switch, you going to create the VLAN in the VLAN database or through the VTP.
After that, you have to create the VLAN interface for that VLAN, specify an IP address for that and enable it by issue the 'no shut' command.
Once you have done it, the interfaces that connects the switch 4507 and 2950 should have the 802.1q (VLAN Trunking) enabled. On the 2950 you may check if the VTP already propagated the VLAN information. If you are not using the VTP, you have to create by yourself manually.
Ok! This is the typical environment. Certify that the VLAN 1 have a interface VLAN created in the 4597 too with an IP address. Check if the workstations you're using have the default gateway correctly configured.
If it is okay, the ping should work.
If you're in doubt with something I told you. Please ask. And if it resolved your problem, please rate.
Best regards,
Rafael Lanna
Hi Rob,
In addtion to the above post, you dont need an IP address on the 2960 switches as such as your 4500 will be doing the routing. As it is layer 2 switch you need an IP addess on 2960, just to manage it remotely. If you have trunk setup correctly between the switches and you have the Layer 3 interfaces ie SVI created for all the vlans on 4500 your routing should work fine.
HTH,
-amit singh
Thanks for the reply. I have done the second and third paragraphs. I created the vlan 405 and gave it an IP address. I verified the vlan in the vlan database of the 4507R. I then applied the 405 vlan to the correct interface. I have dot1q encapsulation on both interfaces that I am trying to trunk. So your saying if they are talking via VTP, it should propagate vlan information from the 4507R to the 2950? When I set 4507R into trunk mode does it automatically turn on VTP? Or do I have to enable it? Also how can I check if the vlan information propagated to the 2950?
Also I am trying to ping from insided the switches, not from a workstation. Again thanks for the help.
Catalyst 4507R
interface Vlan405
description Connection to XXXXXXXXXXXX
Check Vlan propagation with the:
show VLAN BRIEF command
If the VLAN propagated you will see Vlan 405 on the 2950. You will also see which switchports have been assigned to Vlan 405. The port you used to trunk (Gi0/1) WON'T belong to ANY Vlan, that's because it's trunking.
Also, did you assign/configure any switchports into Vlan 405?
Is the 2950 in the same VTP Domain with your 4507 switch? You verify it with this command:
Show VTP STATUS
If the VTP domain is different (case sensitive also), the Vlan information will NOT propagate to the 2950. Also, put the 2950 into Client mode if it is in Server Mode, you can inadvertenly wipe out all your VLANs if the VTP configuration number is higher, belongs to the same domain, is a VTP Server and does not have any of your existing VLANS. If the switch is in Transparent mode change it to Client, Transparent mode will not accept Vlan information/propagations from any other switch. In Transparent mode the Vlans are created locally and not learned from propagated VTP advertisements.
Hi Rob,
When you set the switches on trunk, it doesnot enable the VTP automatically. You have to configure the VTP manually on the switches and then it starts working. You configure one switch as the VTP server and the other switches as VTP clients. You configure the Vlans on the server and if your trunks are working properly the Vlan information via VTP will travel automatically to all the switches configured as Clients.
To check a proper VTP information on the server and client switches run the following commands"
Show vtp status, this will give you info about the
VTP revision number, which should match on all the switches and denotes that the VTP database is sync'd.
Number of vlan, which should be consistent.
Also take out the " switchport access vlan 405 " command from the trunk interfaces, you dont need it. The trunk interfaces should be configured as below:
Catalyst 4507R
Also, as you are trying to ping from the 2950 switch in that case you need an IP address on the switch interface.Without any Ip address on the switch it will not be able to ping anywhere.
Do you have any ip configured on the switch interface? If not, then do the following on 2950 switch:
interface Vlan405
ip address 192.168.122.10 255.255.255.0
no shut
HTH, Please rate if it does.
-amit singh
Thanks for the reply. The 2950 Series has an ip address on it. It's 192.168.122.31. I changed the config and took the switchport access vlan 405 out. Here is what the config says
Catalyst 2950
Catalyst 4507R
interface Vlan405 (On the 4507R)
When I am telneted into the 2950 Series I can't ping 192.168.122.4, which is the Vlan 405 interface on the 4507R Catalyst.
On the 2950 Series I created a vlan 405 and gave it an ip address of 192.168.122.10, but when I try to apply it to the g0/1 interface of the 2950 series, it tells me the ip address overlaps with vlan1, which is 192.168.122.31.
Thanks for the help.
904
