Connecting HP flex-10 10gb CX4 to 6509
I'd like to utilize the 10gb port on the HP flex-10 to connect to my 6509-E.
On the 6509-E, I have dual WS-SUP720-3B with a WS-x6516a-GBIC module.
Is it possible? If so, what will be required.
Many Thanks,
AG
VIP Super Bronze
Re: Connecting HP flex-10 10gb CX4 to 6509
Hi AG,
Yes it is possible.  On the HP the connector type is SFP and on the 6500 the connector type is SC, so you need an LC to SC fiber patch cord to connect the HP to Cisco. If the distance is short you need SR type Connector and cable if the distance is long then you need LR type connector and cable.
Reza
To the 10gb ports on sup720?
ws-x6516a-gbic doesnt support 10gb
The sup is WS-SUP720-3B no 10gb ports.
Hall of Fame Super Gold
Cisco Catalyst 6500 Series 10 Gigabit Ethernet Interface Modules
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet09186a00801dce34.html
Don't forget to rate useful posts.  Thanks.
1847
