Connecting sfp and sfp+ interfaces
Hi all. Here from Spain.
¿How can i connect a Cisco switch Nexus 5000 to a Cisco switch 3750-E at 10 Gpbs of bandwith via copper cables? 3750's switches have a TwinGig module (10Gpbs, SFP interface), and i think also have a X2-10GB-CX4 transceiver module (http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7077/product_data_sheet0900aecd805bbe67.html); cisco Nexus 5000 has SFP+ interfaces. ¿Is it possible? ¿Can i connect sfp to sfp+ and achieve 10Gbps?
Or how can i connect a Qlogic CNA 8152 http://www.qlogic.com/Products/ConvergedNetworking/ConvergedNetworkAdapters/Pages/QLE8152.aspx), SFP+, to a switch with SFP ports (Cisco Catalyst 3560E-12D,  http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7078/product_data_sheet0900aecd805bac22.html).
l ask all these questions because i would like to install a 10G-switched network among a NetApp 3140 and two vmware-servers with qlogic CNAs. And also connect that 10G-switch with a 3750-E stack at 10Gps.
Ufff,
Thanks in advance.
VIP Super Bronze
Re: Connecting sfp and sfp+ interfaces
Hello Ufff,
For 3750-E to connect using 10Gig, you will need the X2-10Gig transceiver module (it could be single mode or multimode). The fiber connecter type you need is SC.
On the Nexus, if you are using a 10Gig SFP, then you need to have an LC type fiber connector.
So, to connect the 3750-E to Nexus, you need  an SC to LC patch cord.
In addition,  on the 3750-E if you want to have 4 1Gig SFPs, instead of 2 X2 10Gig modules you can use TwinGig module to do that.
Reza
Hello Reza.
Ufff was an expression. Here Franky.
Ok. My concept about TwinGig was wrong. Thanks for your answer.
So, Nexus 5000 <-> 3750 = fiber, not CX4 copper, ok?
Nexus 5000 is so expensive...
And, if i had to connect two 3750s via X2-10Gb? Fiber? CX4 copper? Suppose i don't want to stack them.
Now i think... is it possible to join two 3750s via 20Gb-bandwith-Etherchannel?
VIP Super Bronze
Hello Franky!!!!
hmm, what does Ufff mean anyway? (Thanks for clarefication)
Right, fiber if you want to use the 10Gig interfaces
If you want to connect 2 3750s using X2-10Gb, then you have to use fiber
All the copper ports on the 3750 are 10/100/1000 no 10Gig
stacking is a different story.  You use the connectors in the back of the switch with a stacking+ cable to stack them, so don't get theses 2 confused
Yes, you can etherchannel the 2 10Gig from each switch
Reza
Ufff : The first one was a long paragraph in english... i was tired at the end.
And what about Cisco X2-10GB-CX4?, it's copper: (http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6574/product_data_sheet0900aecd801f92aa.html)
From http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7077/product_data_sheet0900aecd805bbe67.html :
X2 for Catalyst 3750-E Series
X2-10GB-ER=
10GBASE-ER X2 Module
X2-10GB-LR=
10GBASE-LR X2 Module
X2-10GB-SR=
10GBASE-SR X2 Module
X2-10GB-CX4=
10GBASE-CX4 X2 Module
X2-10GB-LX4=
10GBASE-LX4 X2 Module
X2-10GB-LRM=
10GBASE-LRM X2 Module
Is it posible? Cheaper? Less perfomance?
3876
