11-07-2006 06:11 AM - edited 03-05-2019 12:39 PM
Hi, our subcontractors have finished the switch install, consisting of two Catalyst 3550 switches connected to each other via a trunk on port 47, with clients and other switches tagged off these switches.
Im having a little trouble understanding the configuration, why has the client switch got an ip address of 192.168.2.10? From my understanding it shouldnt need an address as any packets arriving on its interface will be routed across trunk between the client and core switch, where the core switch will handle the routing?? Or am i totally offtrack? When i remove VLAN3 ip address from the client switch the entire lot goes down, it is obviously needed but i dont understand why.
CORE CONFIG
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime
service sequence-numbers
hostname core
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
spanning-tree vlan 1-3 priority 0
vlan internal allocation policy ascending
interface GigabitEthernet0/1-20
spanning-tree portfast
interface GigabitEthernet0/21-35
switchport access vlan 2
switchport mode access
interface GigabitEthernet0/36-46
switchport access vlan 3
interface GigabitEthernet0/47
description connected to client as a trunk to port 47
switchport mode trunk
interface GigabitEthernet0/50
interface GigabitEthernet0/51
interface GigabitEthernet0/52
interface Vlan1
ip address 192.168.0.2 255.255.255.0
ip helper-address 192.168.0.31
ip helper-address 192.168.0.28
interface Vlan2
interface Vlan3
ip address 192.168.2.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip http server
end
CLIENT CONFIG
version 12.2
no service pad
hostname client
no aaa new-model
vtp domain cisco
vtp mode transparent
ip subnet-zero
ip routing
no file verify auto
vlan 3
name UsersAccess
interface GigabitEthernet0/1-46
description connected to Core Switch As a trunk port
interface Vlan1
ip address 192.168.0.5 255.255.255.0
interface Vlan3
ip address 192.168.2.10 255.255.255.0
ip classless
ip http server
end
Many thanks in advance,
Chris
Solved! Go to Solution.
11-09-2006 02:14 AM
Hi Friend,
HSRP is for redundancy and load sharing when you have two l3 device so that if one goes down another can handle the network.
But because you have one core switch only HSRP is not for your network.
HTH, if yes please rate all helpfull post
Ankur
11-09-2006 04:31 AM
thanks for the reply. when you say core switch what do you mean by that? both switches are the same models.
cheers, i will rate your post.
thanks,
chris
11-09-2006 04:35 AM
Hi Chris,
By Core switch I mean the switch which is handling your core traffic. It does not matter if they are of same model.
Your switch which you have named as client should and is working as a layer 2 switch and your switch to which you have named a core switch is working as layer 3 switch.
The design where you can implement HSRP is like when a layer 2 switch is connected to 2 uplink layer 3 switches and HSRP is configured on both the uplink switches. Your users will sit on layer 2 switch with HSRP ip address as gateway ip address and if incae your core layer 3 switch goes down your second layer 3 switch will take care of your network.
Pls look at the link and this pic will explain you the way HSRP can be implemented
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225see/scg/swhsrp.htm#wp1044171
Ankur
