Connecting two 3550 switches with VLAN IP routing
Hi, our subcontractors have finished the switch install, consisting of two Catalyst 3550 switches connected to each other via a trunk on port 47, with clients and other switches tagged off these switches.
Im having a little trouble understanding the configuration, why has the client switch got an ip address of 192.168.2.10? From my understanding it shouldnt need an address as any packets arriving on its interface will be routed across trunk between the client and core switch, where the core switch will handle the routing?? Or am i totally offtrack? When i remove VLAN3 ip address from the client switch the entire lot goes down, it is obviously needed but i dont understand why.
CORE CONFIG
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime
service sequence-numbers
hostname core
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
spanning-tree vlan 1-3 priority 0
vlan internal allocation policy ascending
interface GigabitEthernet0/1-20
spanning-tree portfast
interface GigabitEthernet0/21-35
switchport access vlan 2
switchport mode access
interface GigabitEthernet0/36-46
switchport access vlan 3
interface GigabitEthernet0/47
description connected to client as a trunk to port 47
switchport mode trunk
interface GigabitEthernet0/50
interface GigabitEthernet0/51
interface GigabitEthernet0/52
interface Vlan1
ip address 192.168.0.2 255.255.255.0
ip helper-address 192.168.0.31
ip helper-address 192.168.0.28
interface Vlan2
interface Vlan3
ip address 192.168.2.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip http server
end
CLIENT CONFIG
version 12.2
no service pad
hostname client
no aaa new-model
vtp domain cisco
vtp mode transparent
ip subnet-zero
ip routing
no file verify auto
vlan 3
name UsersAccess
interface GigabitEthernet0/1-46
description connected to Core Switch As a trunk port
interface Vlan1
ip address 192.168.0.5 255.255.255.0
interface Vlan3
ip address 192.168.2.10 255.255.255.0
ip classless
ip http server
end
Many thanks in advance,
Chris
1 ACCEPTED SOLUTION
Re: Connecting two 3550 switches with VLAN IP routing
Hi Friend,
HSRP is for redundancy and load sharing when you have two l3 device so that if one goes down another can handle the network.
But because you have one core switch only HSRP is not for your network.
HTH, if yes please rate all helpfull post
Ankur
Hi Chris,
In your setup I do not think you need to have layer 3 interface for vlan 3 at all on your client switch. You can only have vlan 1 for mnagement purpose.
The person who had configured your network had confiured both the switches as relay agent and had configured ip helper address on both the switch under interface vlan 3.
In your setup both the switches are configured for routing which I do not think is required.
Consult them and you can remove interface vlan 3 from your client switch or for trail before removing just shut your interface vlan 3.
Also from your core switch under interface gig0/47 remove this command "switchport access vlan 3". To do this run this command "switchport access vlan 3" under interface gig0/47 on core switch.
Now any machine on your client switch which is connected on vlan 3 will hit the core switch which will act as a DHCP relay agent and will get an ip address and for any routing part it will hit the core and core will take care of routing.
Ankur
*pls rate all helpfull post
Hi Chris,
You certainly dont need any IP on vlan 3 on the client switch. You can give it an IP just only to manage it remotely and in that case it can be managed by the Vlan IP.
What is the default-gateway for the clients sitting on the vlan 3 on the client. Please let us know the ip address on one of the client. If you remove the IP from the vlan 3 interface on the client switch the default gateway for the clients should be 192.168.2.1.
Let us know this and we will take it from there.
HTH,
-amit singh
Thanks for the reply, just as i thought but when i configure on the client switch:
interface vlan 3
no ip address
and then telnet is lost. i then need to go back through the core switch (192.168.0.2) and telnet from the ios to 192.168.0.5, that does allow me back in where i can reconfigure the vlan 3 ip address. For some reason it is needed, but doesnt make sense to me.
The users sitting on the vlan 3 client switch have 192.168.2.1 as their default gateway.
Chris
One other thing i would like to keep trunking between the two switches as someday we may stick other vlans on the client switch (rather than all ports as vlan 3), so removing trunk is not an option.
Cheers,
Chris
Hi Chris,
When you can telnet to 192.168.0.2 why can't u telnet directly to 192.168.0.5? Do you have a specific route to reach only 192.168.0.2?
Also no one asked you to remove trunk as it is very well necessary.
Can you update which network/vlan you are into from where you try to telnet?
Ankur
No when i remove the client switches ip address on vlan 3 (192.168.2.10) i can no longer telnet to the client switch on 192.168.0.5?!
Chris,
Cna you attach the full config of both the switch. let us have a look at it and see what's wrong is in there.
-amit singh
Please find attached files,
Cheers,
Chris
Hi Chris,
As I asked in my previous post which VLAN you are from ? Or on which switch you are connected or on which port you are connected from where you ae trying to telnet?
Ankur
Sorry for delayed reply, i am on VLAN3, on the core switch.
once u change the config on the core switch port as above, does it solve ur problem ?
unfortunatly not im afraid. is this something to do with ip routing being enabled on the client? my knowledge is a bit limited so sorry for the silly questions.
Hi Chris,
I got where the problem is when you updated you are in vlan 3. Now when you remove the ip address on vlan 3 on client switch and you try to telnet to vlan 1 ip address from your machine you get routed on your core from vlan 3 to vlan 1 and will reach the client switch but your source ip address will be of vlan 3 subnet and your client switch does not know where to send a reply and is the reason you loose the connectivity when you remove an ip addrses from vlan 3.
Try this out and I am sure you will be good to go
interface vlan 3
shutdown
Then add a default route on your client switch
ip default-gateway
Update us if this resolves your issue and doubt.
Ankur
thanks for the help, that works. i have also read about HSRP... would that be of use in my situation because at the moment the core switch holds everything if that goes ill be up the creek without a paddle!!
Hi Friend,
Ankur
thanks for the reply. when you say core switch what do you mean by that? both switches are the same models.
cheers, i will rate your post.
thanks,
chris
Hi Chris,
By Core switch I mean the switch which is handling your core traffic. It does not matter if they are of same model.
Your switch which you have named as client should and is working as a layer 2 switch and your switch to which you have named a core switch is working as layer 3 switch.
The design where you can implement HSRP is like when a layer 2 switch is connected to 2 uplink layer 3 switches and HSRP is configured on both the uplink switches. Your users will sit on layer 2 switch with HSRP ip address as gateway ip address and if incae your core layer 3 switch goes down your second layer 3 switch will take care of your network.
Pls look at the link and this pic will explain you the way HSRP can be implemented
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225see/scg/swhsrp.htm#wp1044171
Ankur
247
