12-24-2013 11:47 PM - edited 03-07-2019 05:14 PM
Hi all,
I have a problem with a connection to the server, under normal conditions ping from the PC monitor to the server normally. but sometimes there is a failure that resulted in the PC unable to connect to the server.
If I do change the IP address on the PC monitor, Ping goes back to normal or I do service network restart on the server problem is gone. please help me, im stuck at this moment
see the attachment for topology:
Habibi
12-25-2013 07:20 AM
Habibi
Can you provide more details in terms of what the failure actually is ?
In addition, are the switches (sw3/sw4) L3 switches ie. what device is the 192.168.10.254 configured on ?
Jon
12-25-2013 08:17 PM
Hi Jon
Initially the pc monitor can ping the server, and vice versa. in some time these devices can not be connected.
sw3 & sw4 is L2 switches, 192.168.10.254 is FW ASA as a Gateway.
thx for your response
Habibi
12-25-2013 09:04 PM
Expecting that all of the devices have the right subnet-mask then traffic should not reach the Firewall. Traffic should stay on the L2 domain.
That being said:
Next time the issue happens Check
sh interfaces fastEthernet x/x switchport
sh interfaces fastEthernet x/x status err-disabled
show mac address-table interface fastEthernet x/x (Make sure you see the MAC address of the PC/Server on the right ports)
Hope this helps,
Looking for some Networking Assistance?
Contact me directly at jcarvaja@laguiadelnetworking.com
I will fix your problem ASAP.
Cheers,
Julio Carvajal Segura
http://laguiadelnetworking.com
12-25-2013 10:36 PM
Hi jcarvaja
ip address configured static
- PC & server able to ping the Firewall
- no problem with the mac address, errdisable, arp tableRegards,
Habibi
