Connection to the device could not be established. Either the device is not reachable or the HTTP/HTTPS service is not enabled on the device.
jason
This Cisco 800 series has been "handed" to me to get configured...
I am having issues ussing CCP to connect to the device, I am getting"Connection to the device could not be established. Either the device is not reachable or the HTTP/HTTPS service is not enabled on the device."
I know I saved some wrong configuration but having a tough time figuring out where.  Can someone point out to a cisco newb where I am going wrong?
I have checked off the following troubleshooting and can't find where I made my mistake.
or the HTTP service is not enabled on the
device.
This error message is displayed in one of the following conditions:
The internet connection is down.
The IP address of the device is wrong or the device is not reachable.
The CLI "ip route <x.x.x.x> <x.x.x.x> <x.x.x.x>" is missing in the configuration.
The wrong HTTP port is provided to Cisco CP to connect to the device.
The CLI "ip http server" is missing in the configuration for non-secure connection.
The CLI "ip http secure-server" is missing in the configuration for secure connection.
To configure the device as an HTTP or HTTPS server, enter the following commands:
Router> config terminal
Router(config)# ip http server
Router(config)# ip http secure-server
Any help with the proper commands would be greatly appreciated!
881W#show config
Using 5319 out of 262136 bytes
! No configuration change since last restart
! NVRAM config last updated at 14:54:38 PCTime Sat Dec 17 2011
version 15.1
no service pad
hostname 881W
boot-start-marker
boot system flash c880data-universalk9-mz.151-3.T2.bin
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$0IZb$gTe9qzmC2khcz4q7t1H1r0
no aaa new-model
memory-size iomem 10
--More--                           clock timezone PCTime -5 0
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-542214224
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-542214224
revocation-check none
crypto pki certificate chain TP-self-signed-542214224
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
ip source-route
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
   import all
   network 10.10.10.0 255.255.255.248
   default-router 10.10.10.1
   lease 0 2
--More--                           !
ip cef
no ip domain lookup
ip domain name Masternet
no ipv6 cef
license udi pid CISCO881W-GN-A-K9 sn FTX152401DC
username ***** privilege 15 secret 5 $1$FJ5H$buqflzYdL8pf9wOuZE8wm/
class-map type inspect match-any ccp-cls-insp-traffic
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
--More--                            match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
--More--                           class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class class-default
  drop
class class-default
  drop
zone security out-zone
--More--                           zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
--More--                            description $ES_WAN$
no ip address
duplex auto
speed auto
pppoe-client dial-pool-number 1
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface Vlan1
description Bellsouth WAN$FW_INSIDE$$ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
ip nat outside
ip virtual-reassembly in
zone-member security out-zone
ip tcp adjust-mss 1412
interface Dialer0
--More--                            description $FW_OUTSIDE$
ip address negotiated
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname *******
ppp chap password 0 ********
ppp pap sent-username ******** password 0 ********
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-top-talkers
top 10
--by bytes
cache-timeout 3000000
--More--                           !
ip route 0.0.0.0 0.0.0.0 FastEthernet4
logging esm config
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 91 permit any
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 110 permit icmp any any echo
access-list 110 permit icmp any any echo-reply
access-list 110 permit icmp any any source-quench
access-list 110 permit icmp any any packet-too-big
access-list 110 permit icmp any any time-exceeded
dialer-list 1 protocol ip permit
no cdp run
banner login ^CYou are using a network that logs all users activities.  If you are not authorized disconnect now.^C
--More--                           !
line con 0
login local
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
ntp update-calendar
ntp server 24.56.178.140 source Wlan-GigabitEthernet0
ntp server 64.90.182.55 prefer source Wlan-GigabitEthernet0
end
2 Accepted Solutions
take a look at my previous post , this is a ZBF config problem.
Regards.
Alain
int vlan 1
no ip nat ouside
ip nat inside
no zone-member security out-zone
zone-member security in-zone
Regards.
Alain
17 Replies 17
Richard Burts
Jason
Can you tell us what is the source address when you attempt to use CCP? I am guessing that this is the problem. Look at these parts of the config
This says that the router will only accept connections from source addresses 10.10.10.1 through 10.10.10.6.
Rick
Rick
Do you think it is the preffered adapter messing things up?
C:\ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : PC
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 2:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Marvell Yukon 88E8056 PCI-E Gigabit Ether
net Controller #2
   Physical Address. . . . . . . . . : 00-23-54-51-41-F7
   DHCP Enabled. . . . . . . . . . . : No
   Autoconfiguration Enabled . . . . : Yes
   IPv4 Address. . . . . . . . . . . : 10.10.10.2(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.248
   Default Gateway . . . . . . . . . : 10.10.10.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Masternet:
net Controller
   Physical Address. . . . . . . . . : 00-23-54-51-41-F8
   DHCP Enabled. . . . . . . . . . . : Yes
   IPv4 Address. . . . . . . . . . . : 192.168.1.113(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Saturday, December 17, 2011 3:54:53 PM
   Lease Expires . . . . . . . . . . : Sunday, December 18, 2011 3:54:53 PM
   Default Gateway . . . . . . . . . : 192.168.1.254
   DHCP Server . . . . . . . . . . . : 192.168.1.254
   DNS Servers . . . . . . . . . . . : 205.152.144.23
                                       205.152.132.23
                                       192.168.1.254
Tunnel adapter isatap.{319730B2-D3E1-4D78-BC1E-A9F7827A84E8}:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
   IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:1851:27dc:3f57:fe8e(Pref
erred)
   Link-local IPv6 Address . . . . . : fe80::1851:27dc:3f57:fe8e%13(Preferred)
   Default Gateway . . . . . . . . . : ::
   NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{B794DE4E-C0A2-4CC6-A5D3-A5657D38F1B4}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Jason
The PC seems to have 2 IP addresses and I do not see anything in what you posted that tells us which address is being used (and both addresses have the notation that they are preferred). So I am going to assume that it is likely that the device is using the 192.168.1.113 address and that this is causing the problem. I can suggest a couple of things that you could do that would prove this.
- you could add a line to access list 23 that permits 192.168.1.113 (premit the specific host, or permit a range of hosts that include this, or permit the entire 192.168.1.0 network). If you add the line and then access works you have prooved what was the problem and have also achieved a workaround for the problem.
- you could add a line to access list 23 with deny any and specifying the log parameter like this
access-list 23 deny any log
This will generate a log message which should tell you what address is attempting access. This could tell you exactly what the problem is but you would then have to decide whether it is better to do something on the host to get it to use the 10.10.10.2 address or to do something on the router to get it to accept the address.
Rick
As an after-thought can you tell us whether that host has 2 Ethernet cards? Perhaps the solution is as simple as moving the Ethernet connection to the other card.
Rick
Rick,
I did disable the 192.168.1.113 DHCP address and that still proved to not work.  I should of been more clear back when I posted the IPCONFIG.  On your advice I have switched the network cords around, and disabled the 192.x.x.x network for safe keeping.  No luck...
Here is the new access-lists info:
881W(config)#end
881W#
Dec 18 23:13:04.751: %SYS-5-CONFIG_I: Configured from console by ****** on consolewrite
Building configuration...
[OK]
881W#show access-lists
Standard IP access list 23
    10 permit any
Standard IP access list 91
    10 permit any
Extended IP access list 100
    10 permit ip host 255.255.255.255 any
    20 permit ip 127.0.0.0 0.255.255.255 any
Extended IP access list 101
    10 permit ip any any
Extended IP access list 110
    20 permit icmp any any echo-reply
    30 permit icmp any any source-quench
    40 permit icmp any any packet-too-big
    50 permit icmp any any time-exceeded
881W#
As you can see I did the ole permit any and still not working.  Also below is my current IPCONFIG.
   IPv4 Address. . . . . . . . . . . : 192.168.1.122
Ethernet adapter Cisco:
   IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:30:2954:3f57:fe85
   Link-local IPv6 Address . . . . . : fe80::30:2954:3f57:fe85%13
As far the log reporting, here is what I set:
    10 deny   any log
    10 permit any
881W#show log
I took the NIC adapter up and down to make sure I saw active logging, this is the result:
Dec 18 23:32:59.179: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
Dec 18 23:33:06.447: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
Dec 18 23:33:07.447: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
I didn't see any activity from the CCP.  Any more advice?
Jason
Hi Jason,
Could you post your show version output? Make sure you've temporarily disabled your PC FW/AV.
John,
I removed MS Security Essentials, and checked the Windows Firewall and all firewalls(zones) are set to off.  The CCP was working until I made some changes a couple days back.  The system (PC) I am using has not changed in really any way.  I was assuming I made a bonehead change and committed it before checking.  Looking over the config it seemed fine except for the local PC having two NICS.  I was using one NIC for my local LAN, and the other to connect to the CCP on the Cisco 881.
881W#show version
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.1(3)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 10-Aug-11 11:29 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
881W uptime is 3 minutes
System restarted at 23:30:09 PCTime Sun Dec 18 2011
System image file is "flash:c880data-universalk9-mz.151-3.T2.bin"
Last reload type: Normal Reload
--More--
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 881 (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID FTX152401DC
5 FastEthernet interfaces
1 Gigabit Ethernet interface
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco Embedded AP (s)
256K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
--More--
Device#   PID   SN
*0     CISCO881W-GN-A-K9     FTX152401DC
License Information for 'c880-data'
    License Level: advsecurity   Type: Permanent
    Next reboot license Level: advsecurity
hi jason,
can you do the below and try again?
no ip source-route
John,
No luck, still not working and giving the same error.
Latest config:
Using 5344 out of 262136 bytes
! Last configuration change at 10:33:56 PCTime Mon Dec 19 2011 by jmorano
! NVRAM config last updated at 10:33:58 PCTime Mon Dec 19 2011 by jmorano
version 15.1
no service pad
hostname 881W
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
   import all
   lease 0 2
--More--                           !
ip cef
no ip domain lookup
no ipv6 cef
username jmorano privilege 15 secret 5 $1$FJ5H$buqflzYdL8pf9wOuZE8wm/
match protocol dns
match protocol ftp
match protocol h323
match protocol icmp
match protocol pop3
match protocol rtsp
match protocol smtp
match protocol tftp
match protocol tcp
match protocol udp
match protocol icmp
match protocol tcp
match protocol udp
match protocol http
  inspect
class class-default
  pass
  drop log
  inspect
  inspect
class class-default
  drop
class class-default
  drop
no ip address
duplex auto
speed auto
interface wlan-ap0
ip unnumbered Vlan1
arp timeout 0
interface Vlan1
ip nat outside
interface Dialer0
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname *********
no cdp enable
ip http server
ip flow-top-talkers
top 10
sort-by bytes
--More--                           !
logging esm config
access-list 23 permit any
access-list 100 perm  ip 127.0.0.0 0.255.255.255 any
no cdp run
--More--                           !
line con 0
login local
no modem enable
line aux 0
line 2
no exec
transport input all
line vty 0 4
access-class 23 in
privilege level 15
login local
ntp update-calendar
end
Jason
I am a bit confused about how it is configured. First you tell us this:
    10 permit any
but then you also show us this
    10 deny   any log
so I am really confused about the content of access list 23. Perhaps the best solution is to ask you to post a fresh copy of the output of show run.
Rick
Rick
881W#show run
Current configuration : 6594 bytes
! NVRAM config last updated at 23:30:52 PCTime Sun Dec 18 2011
version 15.1
no service pad
hostname 881W
boot-start-marker
boot-end-marker
no aaa new-model
--More--                           memory-size iomem 10
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 35343232 31343232 34301E17 0D313131 32313930 34333035
  315A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3534 32323134
  32323430 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  A25FA6DA 732919AD 52606CBF E0CA905E 6F09C2FE 12A66B53 51D0967A CF4A6CD2
  768A8EF7 8170F01A 00673D2A B8A92FA2 15981052 5C8DE4DF E4AD08CD 89BB75E0
  BB8AFEB0 229DEC04 419019E6 CF51AEF1 54539B92 821FB287 8AE98C43 4337890E
  8F23318F EF02CAD4 7EDB15DC 841D7ACE 731BCB3D A65B1935 5F030EB8 720777E3
--More--                             02030100 01A35330 51300F06 03551D13 0101FF04 0530030F1 01FF301 0603551D
  23041830 16801450 28EB9B88 DC3E5C80 035D3EC8 DA79DEA8 83E11430 1D060355
  1D0E0416 04145028 EB9B88DC 3E5C8003 5D3EC8DA 79DEA883 E114300D 06092A86
  4886F70D 01010405 00038181 0085F224 F8273C2D E639AAA9 BD0D0AD8 775ADDB1
  C38BD8A0 F8EB8A02 AF4A75DE 6E561CAD 524FBA59 31C58805 6EB92D6B 479764E1
  3BFC656D BC0E7C8A C1CEBB28 9D95A202 339E8988 90CF67BC F7BAA4C8 FA31A725
  31439CF7 3C9A6824 BB79C505 FC06F068 B833B27A 4881E93D 20E71EA0 3B4F4E1D
  E9D13421 4C0FF6E6 2A9C063D 02
   quit
ip source-route
   import all
   lease 0 2
ip cef
--More--                           no ip domain lookup
no ipv6 cef
username ******* privilege 15 secret 5 $1$FJ5H$buqflzYdL8pf9wOuZE8wm/
match protocol dns
match protocol ftp
match protocol h323
match protocol icmp
match protocol imap
match protocol pop3
--More--                            match protocol shell
match protocol rtsp
match protocol smtp
match protocol tftp
match protocol tcp
match protocol udp
match protocol icmp
match protocol tcp
match protocol udp
match protocol http
--More--                           !
  inspect
class class-default
  pass
  drop log
  inspect
  inspect
class class-default
  drop
class class-default
  drop
--More--                           zone-pair security ccp-zp-in-out source in-zone destination out-zone
no ip address
duplex auto
--More--                            speed auto
interface wlan-ap0
ip unnumbered Vlan1
arp timeout 0
interface Vlan1
ip nat outside
interface Dialer0
ip mtu 1452
--More--                            zone-member security out-zone
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname ***********
ppp chap password 0 **********
ppp pap sent-username ********** password 0 **********
no cdp enable
ip http server
ip flow-top-talkers
top 10
sort-by bytes
--More--                           logging esm config
no cdp run
line con 0
--More--                            login local
no modem enable
line aux 0
line 2
no exec
transport input all
line vty 0 4
access-class 23 in
privilege level 15
login local
ntp update-calendar
end
Jason
Thanks for posting the output of show run. That clearly shows that the access class is no longer a potential problem. If CCP is still not working then we need to look for something else.
Can you post the output of tracert from your PC to the router?
If you attempt to use CCP do you get any kind of response?
Rick
Rick
class class-default
  drop
interface Vlan1
ip nat outside
you are denying all communication from VLAN1 interface to the router and tht's why CCP is not working.
Just move interface VLAN 1 int zone-security in-zone and it will work
I also noticed you put your inside interface as a NAT outside interface but it should be a NAT inside interface and furthermore I do not see any other NAT configuration. you should configure Dialer interface as NAt outside and then create an ACL for natting in-zone to out-zone Dialer interface and a NAT statement for this like this:
access-list 199 permit ip 10.10.10.0 0.0.0.7 any
ip nat inside source list 199 interface Dialer0
You should also change your default static like this
no ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip route 0.0.0. 0.0.0.0 Dialer0
Also add following global config command for testing your ZBF: ip inspect log drop-pkt
Regards.
Alain
Alain,
Your explanation is now making more sense.  I figured I locked myselrf out by misconfiguring the NAT.  Can you assist in the proper way I can move the Vlan per your comments above?
I greatly appreciate the proper verbiage for the:
Can you assist me in the Vlan move?  Thanks!
Jason
int vlan 1
no ip nat ouside
ip nat inside
Regards.
Alain
