On a C4506 switch [Catalyst 4000 L3 Switch Software (cat4000-I5K91S-M), Version 12.2(25)EWA14] we configured a Layer 2 etherchannel with 4 Gigabit ports with a vmware virtual switch.
=> Vmware suggests the following configuration on the Cisco switch( mode on ):
interface Port-channel1
switchport
switchport access vlan 100
switchport mode access
no ip address
interface GigabitEthernet1/1
switchport
no ip address
channel-group 1 mode on
=> Bellow is the etherchannel as shown on the C4506 switch
B_R0a_Sw2#sh etherchannel 1 detail
Group state = L2
Ports: 4 Maxports = 8
Port-channels: 1 Max Port-channels = 1
Protocol: -
Ports in the group:
Port: Gi5/31
Port state = Up Mstr In-Bndl
Channel group = 1 Mode = On/FEC Gcchange = -
Port-channel = Po1 GC = - Pseudo port-channel = Po1
Port index = 0 Load = 0x00 Protocol = -
Age of the port in the current state: 00d:00h:01m:31s
Port: Gi5/36
Port index = 1 Load = 0x00 Protocol = -
Age of the port in the current state: 00d:00h:01m:01s
Port: Gi5/41
Port index = 2 Load = 0x00 Protocol = -
Age of the port in the current state: 00d:00h:00m:53s
Port: Gi5/45
Port index = 3 Load = 0x00 Protocol = -
Age of the port in the current state: 00d:00h:00m:24s
Port-channels in the group:
Port-channel: Po1
Age of the Port-channel = 05d:23h:32m:47s
Logical slot/port = 11/1 Number of ports = 4
GC = 0x00000000
Port state = Port-channel Ag-Inuse
Protocol = -
Ports in the Port-channel:
Index Load Port EC state No of bits
0 00 Gi5/31 On/FEC 0
1 00 Gi5/36 On/FEC 0
2 00 Gi5/41 On/FEC 0
3 00 Gi5/45 On/FEC 0
Time since last port bundled: 00d:00h:00m:28s Gi5/45
Time since last port Un-bundled: 00d:00h:02m:11s Gi5/41
B_R0a_Sw2#sh run int gi5/31
Building configuration...
Current configuration : 145 bytes
interface GigabitEthernet5/31
description *** NEW BLADES ***
end
B_R0a_Sw2#sh int port-channel 1
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 0013.19f5.20fe (bia 0013.19f5.20fe)
MTU 1500 bytes, BW 4000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is N/A
input flow-control is off, output flow-control is unsupported
Members in this channel: Gi5/31 Gi5/36 Gi5/41 Gi5/45
Last input never, output never, output hang never
Last clearing of "show interface" counters 5d22h
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 1 packets/sec
5 minute output rate 39000 bits/sec, 5 packets/sec
170895104 packets input, 13398135921 bytes, 0 no buffer
Received 1131 broadcasts (23 multicast)
688972569 packets output, 976747229676 bytes, 0 underruns
0 lost carrier, 0 no carrier
B_R0a_Sw2#
B_R0a_Sw2#sh ru int port-channel 1
Current configuration : 94 bytes
switchport
end
B_R0a_Sw2#
Connected to the vmware virtual switch is a server.
The whole setup works OK.
The problem is that when an interface from the bundle fails(eg shut interface Gi5/31(or Gi5/36 or Gi5/41 or Gi5/45)), we have NO connectivity with the server.
When no shut interface Gi5/31 connectivity with the server is back again.
Thank you very much.
have you configured the server correctly for nic teaming , also better to use lacp than mode on where possible , you can cause stp issues sometimes when forcing on just some options to check
Hello Mark, thank you for the reply,
The nic teaming was done by other person. I think it's OK.
Vmware suggests the mode on.
http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1004048
Is it due to the "mode on" that when a link from the bundle fails we lose connectivity with the server?
Thanks again.
Hi no it shouldn't be but you should always use a protocol in etherchannel where possible rather than forcing on even if there example shows on ,protocols negotiate the connection rather than implying what it should be, I would say its the server side causing it ,theres nothing irregular with your config so unless your hitting a bug in the IOS its most likely the vmware setup
If you change it to lacp as a test and you get same issues with that as well as mode on then I would start checking the server side
Copying from the vmware knowledge base:
EtherChannel supported scenarios:
I see that only "mode on" is supported.
I will talk with the vmware technician and if there is nothing more to be done(from his side) i will open a TAC.
Thank you very much Mark.
Will you please check that your vSwitch teaming settings (at vmware side) are as follows:
Load Balancing: Route based on IP hash,
Network Failover Detection: Link Status Only,
and no Standby Adapters configured.
Best regards,
Antonin
Hello Antonin,
I will forward the settings you provided to the vmware tech in case something is missing.
Thank you very much,
Themis.
Yes i agree with what has already been said, we always use LACP with your VM environment for reasons already stated, 9 times out of 10 when we see these issues it is always on the server side (its not our side, as we are network engineers ;0)
