convert OSPF interarea routes (IA) to OSPF E1 for BGP redistrib
I can barely spell OSPF, much less convert it. But here goes.
I need to convert all OSPF inter area routes (IA) to OSPF external routes E1/E2.
This is so my vendors MPLS upstream router on Vlan160 can redistribute
my OSPF into BGP and back to OSPF on 3 sites. Vendor will weight the MPLS
circuits cost to be more desirable than my exsiting circuits.
Cpe6509(ospf)---v160--->VzMPLS-Rtr(bgp)----mplscloud
I only have an Area Zero
The end game here is if the MPLS cloud "dies", my GRE/IPSEC Vpn network running OSPF
will "kick in" and route traffic over it till MPLS come back to life.
---Current----
router ospf 1
router-id 10.122.100.1
log-adjacency-changes
redistribute static subnets route-map VPN
network 10.122.0.0 0.0.255.255 area 0
network 10.250.250.12 0.0.0.3 area 0
network 10.250.250.64 0.0.0.3 area 0
network 10.250.250.76 0.0.0.3 area 0
network 10.250.250.92 0.0.0.3 area 0
network 10.250.250.112 0.0.0.3 area 0
network 10.250.250.128 0.0.0.3 area 0
network 10.250.250.156 0.0.0.3 area 0
network 10.251.251.0 0.0.0.63 area 0
maximum-paths 1
------new----------
My 1st attempt is below:
router ospf 1
redistribute connected metric 1 metric-type 1 subnets route-map OSPF_CONNECTED
redistribute static metric 1 metric-type 1 subnets route-map STATIC
route-map OSPF_CONNECTED permit 10
match interface Vlan160
set tag 1111
route-map STATIC permit 10
match tag 1111
access-list 10 permit 10.122.0.0 0.0.255.255
access-list 10 permit 10.250.250.12 0.0.0.3
access-list 10 permit 10.250.250.64 0.0.0.3
access-list 10 permit 10.250.250.112 0.0.0.3
access-list 10 permit 10.250.250.156 0.0.0.3
Interface Vlan160
Ip add 10.122.160.1
Ip policy route-map OSFP_Connected
IP policy route-map Static
------end-----
So am I close? shouldn't this config let OSPF run normal, but when it
hits Vlan160 it gets tagged so vendor and re-weight/cost the tagged routes?
Hall of Fame Super Silver
Re: convert OSPF interarea routes (IA) to OSPF E1 for BGP redist
hello Doug,
ip policy routing commands ip policy route-map applies to user traffic packets not to routes.
What you need here is a second ospf process running only on the link towards the MPLS provider.
in this second process you can redistribute the routes of ospf process 1 by doing this you convert them to O E2 or O E1 (depending on your choices) and you have a chance to attach the desired route tag value.
Hope to help
Giuseppe
ok so I remove:
nterface Vlan160
Ip add 10.122.160.1
If my border router connected to Vlan160 is running OSPF on process 1, then I don't need to run a 2nd instance of OSPF on my router.
I have:
set tag 1111
This should just allow only OSPF tagged info from OSPF 1 out this Vlan160 interface which connects to my vendors router, correct?
My Mpls provider is going to redistrib the OSPF into BGP on his side. So the Mpls vendor is running OSPF 1 on his device also.
yes/no? Thanks
Hello Doug,
set tag 1111
it is unfortunately wrong.
First of all to pass OSPF E1 routes to someone you need a common subnet where you execute an ospf process using the same Area id and other parameters
So removing vlan 160 is not a good idea if that is the subnet where your device talks with border routers.
The PBR rules have to be removed this is fine.
The route-map that you have suggested does the following:
tries to match interface vlan 160 only
and sets = assigns a route tag of 1111 to the route. (if any)
you basically need :
router ospf 1
network 10.122.160.0 0.0.0.255 area 0
redistribute connected route-map myconn subnets
where the route-map can be expressed as:
route-map myconn permit 10
match ip prefix-list conn_to_advertise
set tag 1111
set type 1
where the prefix-list simply is a list of subnets associated to interfaces you want
to advertise
example:
vlan 50 is 10.122.50.0 255.255.255.0
ip prefix-list conn_to_advertise permit 10.122.50.0/24
and so on you add a line for each vlan / interface you want to advertise.
I recommend you to read more on OSPF for example
http://www.cisco.com/en/US/tech/tk365/technologies_white_paper09186a0080094e9e.shtml
Hope to help
Giuseppe
Since that original post have refined down down to this:
ew ospf Config:
router ospf 1
router-id 10.124.16.1
redistribute connected metric 1 metric-type 1 subnets route-map ospf2mpls
redistribute static metric 1 metric-type 1 subnets route-map static2mpls
network 10.249.249.68 0.0.0.3 area 0
network 10.250.250.24 0.0.0.3 area 0
route-map ospf2mpls permit 16
!add all switch vlans here, no vlan, won't route to that subnet
match interface vlan20
match interface vlan99
match interface vlan100
match interface vlan202
match interface vlan124
match interface vlan8
set tag 10124
route-map static2mpls permit 16
match tag 10124
Guess all I don't have in my config is "Set type 1".
661
