CoPP policy *still* causes high CPU and drops transit tarffic.
We are trying to implement a CoPP policy on your edge router, at the moment this is placed in a Lab to test the effects of the policy. I'm sending a large amount of traffic to ports 22, 443 and 80.
As a test, I have created a policy which rate limits tcp traffic on port 22, 443 and 80.
When we start testing we are still high CPU on the router:
Without CoPP:
Edge_RTR#show proc cpu sorted
CPU utilization for five seconds: 99%/86%; one minute: 92%; five minutes: 78%
 PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  83      993468    110823       8964 11.11% 13.12%  7.80%   0 IP Input
  41      327488    641445        510  0.41%  0.84%  1.04%   0 COLLECT STAT COU
  36        4424    858843          5  0.16%  0.02%  0.00%   0 WLAN LED Timers
   4     1055336     57980      18201  0.08%  0.77%  0.82%   0 Check heaps
   2        1924     25761         74  0.08%  0.01%  0.00%   0 Load Meter
  77       11756   3970594          2  0.08%  0.03%  0.03%   0 ACCT Periodic Pr
 193         648    129232          5  0.08%  0.00%  0.00%   0 DHCP Client
   7           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
CoPP policy applied:
Edge_RTR#show processes cpu sorted
CPU utilization for five seconds: 95%/92%; one minute: 73%; five minutes: 70%
  83      923992    107295       8611  1.63%  0.99%  4.97%   0 IP Input
  41      322040    640993        502  1.47%  1.16%  1.15%   0 COLLECT STAT COU
  27      419356    229495       1827  0.16%  0.35%  0.32%   0 Net Background
  77       11260   3967937          2  0.16%  0.07%  0.04%   0 ACCT Periodic Pr
 120        4704     10410        451  0.16%  0.11%  0.10%   0 TCP Timer
 121        4448      4538        980  0.08%  0.07%  0.07%   0 TCP Protocols
   6           0         2          0  0.00%  0.00%  0.00%   0 Timers
   5          72       117        615  0.00%  0.00%  0.00%   0 Pool Manager
Edge_RTR#show policy-map control-plane
 Control Plane
  Service-policy input: PMAP_CoPP
    Class-map: CMAP_CoPP (match-all)
      165556 packets, 28795230 bytes
      5 minute offered rate 616000 bps, drop rate 612000 bps
      Match: access-group name ACL_CoPP
      police:
          cir 50000 bps, bc 1562 bytes
        conformed 1383 packets, 231750 bytes; actions:
          transmit
        exceeded 164173 packets, 28563480 bytes; actions:
          drop
        conformed 34000 bps, exceed 4094000 bps
    Class-map: class-default (match-any)
      614942 packets, 106927321 bytes
      5 minute offered rate 1769000 bps, drop rate 0 bps
      Match: any
Edge_RTR#
From the above we can confirm the CoPP policy is being actioned, and the IP Input process has dropped from 11% to 1% but we are still seeing high CPU from the router, which causes packet drops for traffic going through the router.
Any help would be apperciated, thank you.
John.
Edge_RTR#show running-config
Building configuration...
Current configuration : 2432 bytes
! Last configuration change at 09:42:42 BST Sat Aug 23 2014 by Cisco
! NVRAM config last updated at 09:26:43 BST Sat Aug 23 2014 by Cisco
version 12.4
no service pad
service password-encryption
hostname Edge_RTR
boot-start-marker
boot-end-marker
logging buffered 20000000
aaa session-id common
clock timezone GMT 0
clock summer-time BST recurring 4 Sun Mar 2:00 4 Sun Oct 3:00
dot11 syslog
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip domain name lab.local
archive
 log config
  hidekeys
class-map match-all CMAP_CoPP
 match access-group name ACL_CoPP
policy-map PMAP_CoPP
 class CMAP_CoPP
    police 50000 conform-action transmit
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
 dsl operating-mode auto
interface FastEthernet0
 switchport access vlan 99
 mac-address 001d.7029.4313
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
 no ip address
 shutdown
 speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
 station-role root
interface Vlan1
 ip address 192.168.3.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly
interface Vlan99
 ip address dhcp
 ip nat outside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list ACL_INSIDE interface Vlan99 overload
ip access-list standard ACL_INSIDE
 permit 192.168.3.0 0.0.0.255
ip access-list extended ACL_CoPP
 permit tcp any any eq 22
 permit tcp any any eq 443
 permit tcp any any eq www
control-plane host
control-plane cef-exception
control-plane
 service-policy input PMAP_CoPP
line con 0
 logging synchronous
 no modem enable
line aux 0
line vty 0 4
 logging synchronous
 transport input ssh
scheduler max-task-time 5000
no scheduler allocate
ntp clock-period 17175062
ntp server 217.114.59.66 source Vlan99
end
82
