Copy one port from another...
ciscom137898
Dear experts,
Is there a way to copy one port config to other port ? i mean seemthing like "copy port X to port Y".. That way the machine will copy the whole config of port X one by one to port Y.
Yosi :)
Jon Marshall
Yosi
You could look into smartport macros which allow you to apply a standard configuration across multiple ports -
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_20_ea2/configuration/guide/swmacro.html#wp1160524
Another option is to use the interface range command eg.
switch(config)# interface range fa0/1 - 10
switch(config-if-range)#
then any commands you type in apply to all ports in the range fa0/1 - 10.
Finally there is good old cut and paste at the CLI prompt.
Jon
Leo Laohoo
Hi Yosi,
Jon's right. I'm using macro and it's alot faster and more accurate than cut-n-paste.
macro apply $tags
Hope this helps. Please rate when applicable.
