Copying ACE certificates to another switch?
I have a 6509 with a ACE module on. The ACE configs need to be used at a DR site which has the same switches are production.
Ive copied the running config from the ACE but see it does not include the certificates.
I see you can use crypto export to do this but this means having to export all the public/private keys separately. Is there an easier way to do this? Can the configs and all certificates be copied across in one go?
Everyone's tags (1)
1 REPLY
Certificates would not be
Certificates would not be copied in such way. You have to export it.
Inayath
17
