07-20-2007 03:42 PM - edited 03-05-2019 05:25 PM
I have a Cat 6509 with a Sup720 card in it. I have two PCMCIA cards. One is running in the switch already (disk0) and the other is blank but formatted (disk1).
All I want to do is copy all of disk0 over to disk1. An exact copy of disk0 to disk1.
I don't want to have to copy each file and dir individually.
copy disk0: disk1: does not do it.
Is there anyway to do this? I am running Version 12.2(18)SXF6.
Any help would be most appreciated.
Thanks!
-Steve
07-20-2007 03:59 PM
Steve,
AFAIK IOS doesn't give you the option of replication between PCMCIA cards. Unfortunately you would have to copy the files individually.
Sundar
07-20-2007 04:09 PM
Hmmm. Thanks Sundar.
I was afraid of that. I have been poking around for the last hour or so trying to find a suitable command.
Bummer :-(
