11-05-2011 10:21 PM - edited 03-07-2019 03:14 AM
Hi all,
Here is logs from 2650 router.
2650XM#$ Nov 5 23:10:13.929 MST: %SIGNATURE-3-NOT_ABLE_TO_PROCESS: %ERROR: Not able to p
rocess Signature in flash:2600-adventerprisek9-mz.124-25d.bin.
Nov 5 23:10:41.963 MST: %SIGNATURE-3-NOT_ABLE_TO_PROCESS: %ERROR: Not able to p
rocess Signature in nvram:.
Nov 5 23:11:26.642 MST: %SYS-2-EXCEPTIONDUMP: System Crashed, Writing Core....
2650XM#$
Right now i am able to access the router .
whats this error about -- is router going to crash or reboot?
What should i do next?
thanks
Solved! Go to Solution.
11-06-2011 02:47 PM
yes, see if you can load the IOS to the flash. Then change the config register to 0x2102 and reboot
11-06-2011 01:44 AM
Hi Mahesh,
when did you notice this error ? Was it when the router was live up and running ?? or during the router reboot??
are you able to see the the startup config using command "show startup-conf" ??
11-06-2011 06:56 AM
Hi Manju,
Thanks for reply.
I saw this error when Router was up and running..
After sometime i lost access to router.
then i console in to router and it was in ROM Mode.
I tried reset command few times.But no luck.
Then i rebooted the router but still it was in ROM mode.
After doing reset command few times it loaded the IOS.
Here is info from
2650XM#sh context
S/W Version: Cisco IOS Software, C2600 Software (C2600-ADVENTERPRISEK9-M), Versi
on 12.4(25d), RELEASE SOFTWARE (fc1)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 18-Aug-10 04:49 by prod_rel_team
Exception occurred at: 23:11:26 MST Sat Nov 5 2011
Exception type: Bus Error (0x0200)
CPU Register Context:
PC = 0x80243C80 MSR = 0x00009032 CR = 0x53009093 LR = 0x802ACEA0
CTR = 0x00002000 XER = 0xA0000F7F DAR = 0x61000000 DSISR = 0x000040C3
DEC = 0x26196017 TBU = 0x00000ABF TBL = 0x59E69FC0 IMMR = 0x68010502
R0 = 0x00000000 R1 = 0x8860E078 R2 = 0x84680000 R3 = 0x60FFFFFC
R4 = 0x88158D50 R5 = 0x00000040 R6 = 0xE966481F R7 = 0x60DBA5E4
R8 = 0x5B373E96 R9 = 0x3831AD9F R10 = 0x802ACE5C R11 = 0x00FFE040
R12 = 0x9091F33F R13 = 0xFFF4B634 R14 = 0x82619F48 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000001 R23 = 0x00000000
R24 = 0x000007FF R25 = 0x00005769 R26 = 0x00000000 R27 = 0x00FFE000
R28 = 0x84D2765C R29 = 0x88156D94 R30 = 0x8516629C R31 = 0x00002000
Stack trace:
Frame 00: SP = 0x8860E078 PC = 0x800AA2D0
Frame 01: SP = 0x8860E088 PC = 0x800AB3B4
Frame 02: SP = 0x8860E0A0 PC = 0x800AE6F0
Frame 03: SP = 0x8860E0D8 PC = 0x800B0DE4
Frame 04: SP = 0x8860E0F8 PC = 0x800AD740
Frame 05: SP = 0x8860E380 PC = 0x800ADA28
11-06-2011 09:28 AM
Hi Mahesh,
For this issue. Have a look at this doc to make sure everything in your router is setup correctly. If not, I recommend downloading an IOS version without any security features and see if you still get the same error messages.
Reza
11-06-2011 09:51 AM
Hi Reza,
So far routers looks ok.
I downloaded this IOS c2600-adventerprisek9-mz.123-26.bin - as it supports MPLS.
Is this IOS version ok -- means no bugs,without security features?
mahesh
11-06-2011 10:04 AM
Mahesh,
Ok, glad you have good version to work with. With IOS images, it is hard to tell, but as long as it is working don't touch it. Remember, 2600 series is pretty old, and may not support all the features you need, but they defiantly provide all the good basics.
Reza
11-06-2011 10:48 AM
Hi Reza,
i did reboot on router to clear the buffer failures log now routet is stuck in ROM
here is info
rommon 2 > confreg
Configuration Summary
(Virtual Configuration Register: 0x2102)
enabled are:
load rom after netboot fails
console baud: 9600
boot: image specified by the boot system commands
or default to: cisco2-C2600
do you wish to change the configuration? y/n [n]: n
rommon 3 > dir flash:
File size Checksum File name
lseek out of bounds
getdirent: lseek error
trying to fix this by url which you send me earlier
thanks
mahesh
11-06-2011 12:05 PM
Hi Mahesh,
Where is the IOS when you do a "dir flash"?
I don't see it in your output.
Reza
11-06-2011 12:22 PM
Hi Reza,
there is no IOS now
rommon 2 > dir flash:
lseek out of bounds
rommon 3 >
rommon 27 > tftpdnld
IP_ADDRESS: 192.168.20.34
IP_SUBNET_MASK: 255.255.255.0
DEFAULT_GATEWAY: 192.168.20.3
TFTP_SERVER: 192.168.20.34
TFTP_FILE: c2600-adventerprisek9-mz.123-26.bin
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash will be lost!
Do you wish to continue? y/n: [n]: y
PHY did not complete auto-negotation, status = 0x100
ARP: address resolution for 192.168.20.34 timed out.
ARP failed with failure code 1. TFTP transfer aborted.
TFTP: Operation terminated prematurely.
lseek out of bounds
rommon 3 >
getting this error again and again
do i need to connect router int fa0/0 with straigh through cable to laptop?
Right now TFTP is on the Laptop and Laptop is getting 192.168.x.x IP from the switch.
thanks
mahesh
11-06-2011 12:30 PM
You need a cross over cable to connect your PC/laptop to the router directly.
If you try it with a cross over cable and it still does not work, you need to use Xmodem to load the IOS
11-06-2011 12:35 PM
hi,
i tried with cross over no luck now will try xmodem.
thanks
mahesh
11-06-2011 01:05 PM
Hi Reza,
tried xmodem get this error
rommon 4 > xmodem -c c2600-adventerprisek9-mz.123-26.bin
Do not start the sending program yet...
lseek out of bounds
WARNING: All existing data in bootflash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n [n]: y
Ready to receive file c2600-adventerprisek9-mz.123-26.bin ...
BB0
ERR:Image size exceeds free flash space
rommon 5 >
BB0
ERR:Image size exceeds free flash spaceReady to receive file c2600-adventerprisek9-mz.123-26.bin ...
BB0
what can i try next?
thanks
11-06-2011 01:08 PM
try deleting/erasing the existing files on the flash before loading the new one
11-06-2011 01:15 PM
What command i can use on ROM mode?
11-06-2011 01:22 PM
i use this option to download file to DRAM
xmodem -r c2600-adventerprisek9-mz.123-26.bin
once this is done then is there any way i can transfer from dram to flash?
thanks
mahesh
