Copying IOS from DRAM to flash -- ROM Mode
Hi all,
Here is logs from 2650 router.
2650XM#$ Nov  5 23:10:13.929 MST: %SIGNATURE-3-NOT_ABLE_TO_PROCESS: %ERROR: Not able to p
rocess Signature in flash:2600-adventerprisek9-mz.124-25d.bin.
Nov  5 23:10:41.963 MST: %SIGNATURE-3-NOT_ABLE_TO_PROCESS: %ERROR: Not able to p
rocess Signature in nvram:.
Nov  5 23:11:26.642 MST: %SYS-2-EXCEPTIONDUMP: System Crashed, Writing Core....
2650XM#$
Right now i am able to access the router .
whats this error about -- is router going to crash or reboot?
What should i do next?
thanks
1 ACCEPTED SOLUTION
VIP Super Bronze
yes, see if you can load the IOS to the flash.  Then change the config register to 0x2102  and reboot
Bronze
system crashed - writing core on router logs
Hi Mahesh,
when did you notice this error ? Was it when the router was live up and running ?? or during the router reboot??
are you able to see the the startup config using command "show startup-conf" ??
Hi Manju,
Thanks for reply.
I saw this error when Router  was up and running..
After sometime i lost access to router.
then i console in to router and it was in ROM Mode.
I tried reset command few times.But no luck.
Then i rebooted the router but still it was in ROM  mode.
After doing reset command few times it loaded the IOS.
Here is info from
2650XM#sh context
S/W Version: Cisco IOS Software, C2600 Software (C2600-ADVENTERPRISEK9-M), Versi
on 12.4(25d), RELEASE SOFTWARE (fc1)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 18-Aug-10 04:49 by prod_rel_team
Exception occurred at: 23:11:26 MST Sat Nov 5 2011
Exception type: Bus Error (0x0200)
CPU Register Context:
PC  = 0x80243C80  MSR = 0x00009032  CR  = 0x53009093  LR    = 0x802ACEA0
CTR = 0x00002000  XER = 0xA0000F7F  DAR = 0x61000000  DSISR = 0x000040C3
DEC = 0x26196017  TBU = 0x00000ABF  TBL = 0x59E69FC0  IMMR  = 0x68010502
R0  = 0x00000000  R1  = 0x8860E078  R2  = 0x84680000  R3    = 0x60FFFFFC
R4  = 0x88158D50  R5  = 0x00000040  R6  = 0xE966481F  R7    = 0x60DBA5E4
R8  = 0x5B373E96  R9  = 0x3831AD9F  R10 = 0x802ACE5C  R11   = 0x00FFE040
R12 = 0x9091F33F  R13 = 0xFFF4B634  R14 = 0x82619F48  R15   = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00000000  R19   = 0x00000000
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00000001  R23   = 0x00000000
R24 = 0x000007FF  R25 = 0x00005769  R26 = 0x00000000  R27   = 0x00FFE000
R28 = 0x84D2765C  R29 = 0x88156D94  R30 = 0x8516629C  R31   = 0x00002000
Stack trace:
Frame 00: SP = 0x8860E078    PC = 0x800AA2D0
Frame 01: SP = 0x8860E088    PC = 0x800AB3B4
Frame 02: SP = 0x8860E0A0    PC = 0x800AE6F0
Frame 03: SP = 0x8860E0D8    PC = 0x800B0DE4
Frame 04: SP = 0x8860E0F8    PC = 0x800AD740
Frame 05: SP = 0x8860E380    PC = 0x800ADA28
VIP Super Bronze
Hi Mahesh,
For this issue.  Have a look at this doc to make sure everything in your router is setup correctly.  If not, I recommend downloading an IOS version without any security features and see if you still get the same error messages.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a0080094ae0.shtml#bus_error_exception
Reza
Hi Reza,
So far routers looks ok.
I downloaded this IOS    c2600-adventerprisek9-mz.123-26.bin   -  as it supports MPLS.
Is this IOS  version  ok -- means no bugs,without security features?
mahesh
VIP Super Bronze
Mahesh,
Ok, glad you have good version to work with.  With IOS images, it is hard to tell, but as long as it is working don't touch it. Remember,  2600 series is pretty old, and may not support all the features you need, but they defiantly provide all the good basics.
Reza
Hi Reza,
i did reboot on router to clear the buffer failures log now routet is stuck in ROM
here is info
rommon 2 > confreg
           Configuration Summary
   (Virtual Configuration Register: 0x2102)
enabled are:
load rom after netboot fails
console baud: 9600
boot: image specified by the boot system commands
      or default to: cisco2-C2600
do you wish to change the configuration? y/n  [n]:  n
rommon 3 > dir flash:
         File size           Checksum   File name
lseek out of bounds
getdirent: lseek error
trying to fix this by url which you send me earlier
thanks
mahesh
VIP Super Bronze
Hi Mahesh,
Where is the IOS when you do a "dir flash"?
I don't see it in your output.
Reza
Hi Reza,
there is no IOS now
rommon 2 > dir flash:
lseek out of bounds
rommon 3 >
rommon 27 > tftpdnld
          IP_ADDRESS: 192.168.20.34
      IP_SUBNET_MASK: 255.255.255.0
     DEFAULT_GATEWAY: 192.168.20.3
         TFTP_SERVER: 192.168.20.34
           TFTP_FILE: c2600-adventerprisek9-mz.123-26.bin
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash will be lost!
Do you wish to continue? y/n:  [n]:  y
PHY did not complete auto-negotation, status = 0x100
ARP: address resolution for 192.168.20.34 timed out.
ARP failed with failure code 1.  TFTP transfer aborted.
TFTP: Operation terminated prematurely.
lseek out of bounds
rommon 3 >
getting this error again and again
do i need to connect router int fa0/0  with straigh through cable to laptop?
Right now TFTP is on the Laptop and Laptop is getting 192.168.x.x IP  from the switch.
thanks
mahesh
VIP Super Bronze
You need a cross over cable to connect your PC/laptop to the router directly.
If you try it with a cross over cable and it still does not work, you need to use Xmodem to load the IOS
hi,
i tried with cross over no luck now will try xmodem.
thanks
mahesh
Hi Reza,
tried xmodem get this error
rommon 4 >  xmodem -c c2600-adventerprisek9-mz.123-26.bin
Do not start the sending program yet...
lseek out of bounds
WARNING: All existing data in bootflash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n  [n]:  y
Ready to receive file c2600-adventerprisek9-mz.123-26.bin               ...
BB0
ERR:Image size exceeds free flash space
rommon 5 >
BB0
ERR:Image size exceeds free flash spaceReady to receive file c2600-adventerprisek9-mz.123-26.bin               ...
BB0
what can i try next?
thanks
VIP Super Bronze
try deleting/erasing the existing files on the flash before loading the new one
What command i can use on ROM  mode?
i use this option to download file to DRAM
xmodem -r c2600-adventerprisek9-mz.123-26.bin
once this is done then is there any way i can transfer from dram to flash?
thanks
mahesh
VIP Super Bronze
hi.
Now Router is back but FLASH is empty as IOS is in DRAM.
2650XM#sh flash
System flash directory:
No files in System flash ****************************************************************************
[0 bytes used, 16777212 available, 16777212 total]
16384K bytes of processor board System flash (Read/Write)
sh ver shows
2650XM#sh ver
IOS (tm) C2600 Software (C2600-ADVENTERPRISEK9-M), Version 12.3(26), RELEASE SOF
TWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 15:23 by dchih
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
2650XM uptime is 3 minutes
Running default software  *******************************************************************
should i try to copy ios from TFTP to Router so that it can store in FLASH?
Also config reg shows
Configuration register is 0x3922
VIP Super Bronze
i get error
650XM#copy tftp flash:
Address or name of remote host [192.168.20.36]?
Source filename [c2600-adventerprisek9-mz.123-26.bin]?
Destination filename [c2600-adventerprisek9-mz.123-26.bin]?
Accessing tftp://192.168.20.36/c2600-adventerprisek9-mz.123-26.bin...
Erase flash: before copying? [confirm]
Erasing the flash filesystem will remove all files! Continue? [confirm]
Erasing device... eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
ee ...erased
Erase of flash: complete
Loading c2600-adventerprisek9-mz.123-26.bin from 192.168.20.36 (via FastEthernet
1/0): !
%Error copying tftp://192.168.20.36/c2600-adventerprisek9-mz.123-26.bin (Not eno
ugh space on device)
ee ...erased
1/0): !
VIP Super Bronze
Mahesh,
Here is the problem.  Your flash is 16Mb and the IOS you are trying to load is 17Mb, so it will not fit into your flash.  you need an IOS that is smaller the 16Mb.
here is what you have
ENTERPRISE/SNASW PLUS IPSEC 3DES
c2600-a3jk9s-mz.123-26.bin
Release Date: 18/MAR/2008
Size: 20929.02 KB (21431316 bytes)
Minimum Memory:        DRAM:96MB        Flash:32MB
Hi Reza,
Thats not correct before this issue i had this memory
650XM#sh ver
Cisco IOS Software, C2600 Software (C2600-ADVENTERPRISEK9-M), Version 12.4(25d), RELEASE SOFTWARE (fc1)
2650XM uptime is 13 minutes
System returned to ROM by reload at 00:20:21 MST Sun Nov 6 2011
System restarted at 00:24:58 MST Sun Nov 6 2011
System image file is "flash:c2600-adventerprisek9-mz.124-25d.bin"
--More--                           A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2650XM (MPC860P) processor (revision 3.0) with 253952K/8192K bytes of memory.
Processor board ID JAE08116F4Y
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
1 Serial interface
1 Virtual Private Network (VPN) Module
32K bytes of NVRAM.
49152K bytes of processor board System flash (Read/Write)  ****************************************
currently IOS  is in DRAM  which i did from Xmodem.
is there way i can erase all flash i did few times but still it is not showing up correct memory\\\\?
I do not know if its impolite to butt in, but maybe you could try the squeeze command now.
Software Configuration GuideFor Cisco 2600 Series Routers
http://www.cisco.com/en/US/docs/routers/access/3700/software/configuration/guide/swconfig.pdf
squeeze {flash: | slot0:
} command.
in your case squeeze flash:
Read the PDF, search for squeeze.
Good luck.
Hi Reza,
See the previous sh ver  from same router
2650XM#sh tech-support
------------------ show version ------------------
2650XM uptime is 4 weeks, 2 hours, 1 minute
System restarted at 21:25:49 MST Sat Oct 8 2011
export@cisco.com.
Cisco 2650XM (MPC860P) processor (revision 3.0) with 253952K/8192K bytes of memory.  *****************256DRAM
1 Serial interface
32K bytes of NVRAM.
49152K bytes of processor board System flash (Read/Write)  *************************48 MB  FLASH
Seems my router is showing up less memory both DRAM  and FLASH.
Shouild i reload it ?
Mahesh
I do not know if its impolite to **** in, but maybe you could try the squeeze command now.
squeeze {flash: | slot0:} command.
Good luck.
thanks for reply i already tried squueze and other commands
still no luck.
i do not know if i reboot the router then if it will come back or not?
thanks
Hi Reza,
Issue is fixed.
This IOS  was bad ---  as it was showing very less Flash and DRAM  on my Router.
Also this IOS  -- while using xmodem with c option was not working at all.
I tried many times but no luck.
Then from ROM mode i used Xmodem and copy this IOS
c2600-advipservicesk9-mz.123-26.bin.
Now all is good
cisco 2650XM (MPC860P) processor (revision 0x300) with 126976K/4096K bytes of me
mory.
Processor board ID JAE08116F4Y (4085259298)
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
1 Virtual Private Network (VPN) Module(s)
32K bytes of non-volatile configuration memory.
2650XM# sh flash
File  Length   Name/status
  1   20146776  c2600-advipservicesk9-mz.123-26.bin
[20146840 bytes used, 30184804 available, 50331644 total]
49152K bytes of processor board System flash (Read/Write)  ************************Correct amount of Flash.
Thanks for all the help
2650XM#
2083
