08-18-2012 01:18 AM - edited 03-07-2019 08:24 AM
Dears,
I will go to buy a core 4506 but I'm comfusing about the Sup engines and the Fiber module so please can you support me in the following:-
what is the different between the Sup7 and Sup7L??
in the fiber module that I will go to buy is it contain the SFP inside or I have to buy the SFP ( WS-X4612-SFP-E ). also what is the different between the SFP and GBIC??
Appreciate your kindly support,
08-18-2012 01:45 AM
Hi ,
Check this pic:
GBIC - Datasheet definition:
The industry-standard Cisco Gigabit Interface Converter (GBIC) is a hot-swappable input/output device that plugs into a Gigabit Ethernet port or slot, linking the port with the network. Cisco GBICs can be interchanged on a wide variety of Cisco products and can be intermixed in combinations of 1000BASE-T, 1000BASE-SX, 1000BASE-LX/LH, 1000BASE-ZX, or 1000BASE-CWDM interfaces on a port-by-port basis.
SFP - Datasheet definition:
The industry-standard Cisco® Small Form-Factor Pluggable (SFP) Gigabit Interface Converter is a hot-swappable input/output device that plugs into a Gigabit Ethernet port or slot, linking the port with the network (Figure 1). SFPs can be used and interchanged on a wide variety of Cisco products and can be intermixed in combinations of 1000BASE-SX, 1000BASE-LX/LH, 1000BASE-ZX, or 1000BASE-BX10-D/U on a port-by-port basis.
Ok, now if you have a look at the above datasheets for GBIC's & SFP's, you would find that GBIC & SFP are different in there sizes, hence it is more of a question as to which gigabit solution your device supports. If your device supports GBIC, like 4500's, you will have to go for a GBIC, & if your device supports SFP, like 3750's, you will have to go for a SFP. These days all the latest devices would have SFP's normally.
Also, here is a very good document which lists almost all the GBIC's & SFP's & the devices on which they are supported, you may check your device on this list & decide which one can you use accordingly.
08-18-2012 02:49 AM
The Data Sheet for the Sup7E and the Sup7LE are found below:
Cisco Catalyst 4500E Supervisor Engine 7-E
Cisco Catalyst 4500E Supervisor Engine 7L-E
Please take note that these supervisor engines will only work with "-E", "R-E" or "R+E" chassis. Legacy 4000/4500 chassis will not be supported.
At the bottom of the page, there's a section called "Supported Cisco Catalyst 4500E Series Line Cards and Modules" and this will guide you whether or not your line card is supported.
08-18-2012 10:27 AM
Dears,
As I understood that I have to buy the SFP adapters seperately than the module where the module ports is empty.
Also I have edge switches in the floors (Planet edge switch) so the fiber port I will use is SFP also I have to check the cable if it single or multi mode??
Please advise,
08-18-2012 11:30 PM
Of course, SFP modules are always an add-on purchase.
That is correct. You need to determine if what kind of fibre is being used in your inter-floor fibre run. It could either be single-mode or multi-mode.
