Webcast-Catalyst9k
cos and dscp
Hi all, If I get my switch to mark the cos values from a specific vlan, when this traffic then moves to the next switch, if I dont set the uplink to trust these frames, what will happen will the frame still keep its marking?
Re: cos and dscp
If you don't configure the trust on the interface the cos value will be changed to back to zero.
HTH,
Mark
Silver
Re: cos and dscp
What mark has said is correct unless the next switch doesn't have mls qos enabled (Globaly). Then the QoS marking will stay and will be forwarded.
Re: cos and dscp
If your ip phones (Avaya in our case) are marking the voice packets such as dscp 46 and call control af31 and you have your cos-dscp map set correctly is it best to trust cos of dscp on the trunks between layer 2 switches? What about the trunk interface on the switch connecting to a router?
202
