Coverter BNC to RJ45
Hi.
I need to use in my solution coaxial cable in 10 switches. There is some converter coaxial cable(BNC) to RJ-45?
Pet
purohit_810
Level 5
Level 5
Hi Pet,
Yes, You can order by amazon or ebay.
D-Link Transceiver 10MBs RJ45 BNC Medi A Converter
Look on link
http://www.amazon.com/D-Link-Transceiver-10MBs-RJ45-Converter/dp/B00004Z86P
There are so many vendors,they are making BNC to RJ-45 Converters.
Dharmesh Purohit
mkonarski3
look for a transciever, like fiber to copper (ie. 100FX to 100TX), but look for 10base2 or 10base5 whatever you using to 10/100 Ethernet (i'm assuming this is what you are referring to by rj-45)
