cpu usegae high 70 to 80 percent
Dear Sir,
We are having some problem with a router's cpu usage. Currently it handling only 30 mbps bandwidth. When bandwidth goes to 27 mb its cpu usage reaches to 75% or above. I am attaching some of its configuraiton portion. Could you please let know whether there is any problem or not or its normal with this router.
sh ver Output:
IOS (tm) 3600 Software (C3640-IS-M), Version 12.2(12g), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Mon 11-Aug-03 15:08 by cmong
Image text-base: 0x60008930, data-base: 0x610F6000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Optimax_GW uptime is 1 week, 4 days, 20 hours, 10 minutes
System returned to ROM by reload
System image file is "flash:c3640-is-mz.122-12g.bin"
cisco 3640 (R4700) processor (revision 0x00) with 125952K/5120K bytes of memory.
Processor board ID 19737278
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
2 FastEthernet/IEEE 802.3 interface(s)
4 Serial network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
interface FastEthernet0/0
description "Connected To BTCL"
ip address 123.49.0.138 255.255.255.252
no ip redirects
no ip proxy-arp
speed auto
full-duplex
interface FastEthernet0/1
description "Connected To Lan Router"
ip address 203.112.79.125 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip mroute-cache
speed auto
full-duplex
no cdp enable
interface Serial2/0
description "Connected to VSAT"
ip address 202.133.15.106 255.255.255.252
ip route-cache flow
no keepalive
no fair-queue
serial restart-delay 0
no cdp enable
router bgp 38031
bgp log-neighbor-changes
network 114.134.88.0 mask 255.255.255.0
network 114.134.89.0 mask 255.255.255.0
network 114.134.90.0 mask 255.255.255.0
network 114.134.91.0 mask 255.255.255.0
network 114.134.92.0 mask 255.255.255.0
network 114.134.93.0 mask 255.255.255.0
network 114.134.94.0 mask 255.255.255.0
network 114.134.95.0 mask 255.255.255.0
network 114.134.88.0 mask 255.255.248.0
network 203.112.72.0
network 203.112.73.0
network 203.112.74.0
network 203.112.75.0
network 203.112.76.0
network 203.112.77.0
network 203.112.78.0
network 203.112.79.0
network 203.112.72.0 mask 255.255.248.0
neighbor 123.49.0.137 remote-as 17494
neighbor 123.49.0.137 prefix-list default in
neighbor 123.49.0.137 prefix-list bttb out
neighbor 123.49.0.137 route-map localpref in
neighbor 123.49.0.137 filter-list 1 out
neighbor 202.133.15.105 remote-as 24399
neighbor 202.133.15.105 description eBGP with ASIX-HKG AS-24399
neighbor 202.133.15.105 version 4
neighbor 202.133.15.105 prefix-list asixdefault in
neighbor 202.133.15.105 route-map localpref2 in
neighbor 202.133.15.105 route-map asix-prepend out
neighbor 203.112.79.121 remote-as 38031
neighbor 203.112.79.121 update-source Loopback0
neighbor 203.112.79.121 version 4
neighbor 203.112.79.121 next-hop-self
neighbor 203.112.79.121 send-community
neighbor 203.112.79.121 soft-reconfiguration inbound
Thanks in advance.
Tuhin
Dhaka. BD.
Silver
Re: cpu usegae high 70 to 80 percent
On f0/1 and s2/0 netflow is turned on "ip route-cache flow".
Perform a show processor to see if this is the cause.
Normally netflow is hardware switched 6500, need to get back to you how processed for 3640
Silver
Please see enclosed URL for Cisco Netflow Testing across various platforms including 3640
http://www.cisco.com/en/US/technologies/tk543/tk812/technologies_white_paper0900aecd802a0eb9_ps6601_Products_White_Paper.html
Super Bronze
A 3640 is rated at 50 to 70 Kpps. Pushing 30 Mbps, especially if duplex, could easily account for the CPU demand you're seeing. You didn't note whether the high CPU is "interrupt" CPU, but if it is, then it's very likely you've hitting the maximum forwarding capacity of the router.
I've attached a document which will provide you the performance specification for many Cisco routers.
149
