Community Member
CRC count from a c7200 VPN box to a 2912-xl switch
So let's see.
I have two VPN routers that are connected to two seperate Switches for failover.
I'm getting CRC erros on the switchport that the router is plugged into (no matter what port I plug it into) I've verified duplex and speed, I've also changed the cable out. Doesn't matter what port I plug the router into the crc's start to count up. No crc's on the routers interface.
Anyone?
Hall of Fame Super Bronze
Re: CRC count from a c7200 VPN box to a 2912-xl switch
You've performed all the correct steps and it seems you have a bad switch, it happens ! :)
That switch is quite old as well.
Have you tried connecting another device to this switch and see if you can duplicate the CRC errors ?
Have you tried upgrading the firmware ?
__
Edison.
Community Member
Just updated the switch last night. There are other devices using the switch without any problems at all. Even when the router is in standby mode there are no CRC's on the switchport it's plugged into. It seems that only the VPN traffic causes it. Doesn't make any sense to me, but I thought that maybe because all the switchports are in a vlan it might have something to do with how the Gig interface on the router is configured. Do I need to encasuplate dot1q on that interface going to the switch? Also this happens on both my outside switches, I don't see how both switches can be bad.
You don't need dot1q unless you are planning to carry more than one Vlan on the link.
Make sure to configure the switch as access-vlan and the router as a normal routed port.
Please post the portion or the entire config from both devices, maybe there is something in the configuration that needs correcting.
Community Member
This is the config for the gig interface
interface GigabitEthernet0/1
description Outside
ip address XX.XX.XXX.XX XXX.XXX.XXX.XXX
ip virtual-reassembly
ip tcp adjust-mss 1300
duplex full
speed 100
media-type rj45
no negotiation auto
no cdp enable
standby delay minimum 30 reload 60
standby 2 ip XX.XX.XXX.XX
standby 2 timers 1 10
standby 2 preempt
standby 2 name ha-out
standby 2 track GigabitEthernet0/2
crypto map clientmap redundancy ha-out stateful
This is the interface on the switch
interface FastEthernet0/9
description VPN Router .XX
mtu 1500
duplex full
speed 100
switchport access vlan 110
no cdp enable
This is the "show int fast 0/9" on the switch
NMM-2912-1-Outside#sh int fastEthernet 0/9
FastEthernet0/9 is up, line protocol is up
Hardware is Fast Ethernet, address is 0004.4dd0.4889 (bia 0004.4dd0.4889)
Description: VPN Router .13
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive not set
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input never, output 02:45:25, output hang never
Last clearing of "show interface" counters 03:27:21
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
4251524 packets input, 2530110338 bytes
Received 2494 broadcasts, 0 runts, 0 giants, 0 throttles
25 input errors, 25 CRC, 0 frame, 27 overrun, 27 ignored
0 watchdog, 2494 multicast
4377529 packets output, 1375471044 bytes, 0 underruns
0 lost carrier, 0 no carrier
Change speed/duplex to auto/auto
Clear counters
Let's see if the CRC increases again.
Weird, let me do some digging...
Can you eliminate the MTU statement on the 2900 side? I don't see the purpose of it as the default MTU size is 1500.
Community Member
By the way something I forgot to mention.
We RMA'd the first 2912xl that was doing this. This is the second one CISCO has sent. Same problem.
Then, it seems a compatibility issue between the 29xx and the Giga interface in the 7200
or
the configuration at one of the ports.
Can we eliminate the speed/duplex and mtu as I suggested ?
193
