06-23-2012 12:09 AM - edited 03-07-2019 07:24 AM
Dear All,
One of my wi-fi site having 2nos cisco 2950 switchs. in that network some D-link unmanageble swithes also there
and access points also connected to cisco switchs and D-link switchs.
after one or two days i am not able to connect the wi-fi, then i need to restart the access point then only wi-fi is working fine.
I upgraded the latest ios also.
I connected some access points to the cisco switch ports, those ports are showing crc error messages like below.
145 input errors, 144 CRC, 1 frame, 0 overrun, 0 ignored
and log file also show some errors like below.
000186: Jun 23 03:44:01: %SYS-5-CONFIG_I: Configured from console by vty0 (115.1
19.187.45)
000187: Jun 23 05:44:36: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEth
ernet0/5, changed state to down
000188: Jun 23 05:44:38: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEth
ernet0/5, changed state to up
000189: Jun 23 06:38:19: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEth
000190: Jun 23 06:38:21: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEth
000191: Jun 23 06:38:25: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEth
000192: Jun 23 06:38:27: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEth
what could be the problem,
I updated the lates IOS and changed the RJ45 connector both side.
Plz help on this.
Srinivas. N.
06-23-2012 12:14 AM
Kindly post the output to the following commands:
1. sh run int f 0/5;
2. sh contr e f 0/5
3. sh interface f 0/5
06-23-2012 12:50 AM
Hi leolaohoo,
Thanks for reply and plz find the sataus.
GP_VIZAG_MAINSW_2950#sh run int fa0/5
Building configuration...
Current configuration : 122 bytes
interface FastEthernet0/5
description * Back Side-I (Proxim) *
switchport access vlan 10
switchport mode access
end
GP_VIZAG_MAINSW_2950#sh cont
GP_VIZAG_MAINSW_2950#sh controllers e
GP_VIZAG_MAINSW_2950#sh controllers ethernet-controller fa0/5
Transmit Receive
4111734682 Bytes 800406706 Bytes
5324004 Frames 3132634 Frames
723276 Multicast frames 167 FCS errors
411370 Broadcast frames 51740 Multicast frames
0 Pause frames 21924 Broadcast frames
0 Single defer frames 0 Control frames
0 Multiple defer frames 0 Pause frames
0 1 collision frames 0 Unknown opcode frames
0 2-15 collisions 1 Alignment errors
0 Late collisions 0 Length out of range
0 Excessive collisions 122 Symbol error frames
0 Total collisions 61932 False carrier errors
0 Control frames 0 Valid frames, too small
0 VLAN discard frames 0 Valid frames, too large
0 Too old frames 0 Invalid frames, too small
0 Tagged frames 0 Invalid frames, too large
0 Aborted Tx frames 0 Discarded frames
Transmit and Receive
1355392 Minimum size frames
2785635 65 to 127 byte frames
930782 128 to 255 byte frames
291326 256 to 511 byte frames
284047 512 to 1023 byte frames
2809456 1024 to 1518 byte frames
0 1519 to 1522 byte frames
GP_VIZAG_MAINSW_2950#sh int
GP_VIZAG_MAINSW_2950#sh interfaces fa0/5
FastEthernet0/5 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0012.00fe.d6c5 (bia 0012.00fe.d6c5)
Description: * Back Side-I (Proxim) *
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 100BaseTX
input flow-control is unsupported output flow-control is unsupported
Last input never, output 00:00:01, output hang never
Last clearing of "show interface" counters 2d02h
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 1000 bits/sec, 1 packets/sec
1902845 packets input, 534271423 bytes, 0 no buffer
Received 42355 broadcasts (28994 multicast)
0 watchdog, 28994 multicast, 0 pause input
2943416 packets output, 2240492645 bytes, 0 underruns
06-23-2012 12:54 AM
Ok, good.
Your line errors are mostly coming from FCS and Symbols.
Mostly, this is attributed due to faulty cabling.
What do you mean by this?
Are you using a factory pre-terminated patch cables or did you crimp them yourself?
06-23-2012 01:02 AM
Thanks for quick reply,
what is meangin of FCS and symbols?
The cat cable is about to 70mts and i my self crimped the connectors.
06-23-2012 02:22 AM
Test the cables with a TDR meter.
06-25-2012 12:41 PM
Hi Leolaohoo,
After reclimping the RJ45 connetors and clear the counter.
Now that port status like below
GP_VIZAG_MAINSW_2950# sh controllers e f0/5
Transmit Receive
880211912 Bytes 342010269 Bytes
1214521 Frames 913135 Frames
139288 Multicast frames 0 FCS errors
96737 Broadcast frames 5471 Multicast frames
0 Pause frames 2198 Broadcast frames
0 2-15 collisions 0 Alignment errors
0 Excessive collisions 0 Symbol error frames
0 Total collisions 134 False carrier errors
406912 Minimum size frames
681005 65 to 127 byte frames
205184 128 to 255 byte frames
63193 256 to 511 byte frames
82091 512 to 1023 byte frames
689271 1024 to 1518 byte frames
now advice me,...
06-25-2012 03:37 PM
Looks good to me. FCS and Symbol errors are "0", no collisions.
06-25-2012 05:25 PM
what about the
no problem?
06-25-2012 10:26 PM
No problem? Are you looking for one? Because with all the counters I am sure you can find one if you look hard enough.
My boss once told me there was no such thing as a perfect design, I disagreed...I said "What about Holly Madiison, now thats a perfect design ". I am just saying lol!
Moving on .... Check out:
https://supportforums.cisco.com/thread/157286
and from Ciscos site:
False carrier errors | The number of occurrences in which the interface detects a false carrier when frames are not sent or received. |
IMO, while I have not seen this type of error before, you are seeing speed/duplex mismatches disguised as false carrier or a pure layer one issue.
06-26-2012 03:14 AM
I'm with Jimmy. I have never seen this line error before. I didn't miss this.
Keep an eye on the counter. If the counter goes up, by 50%, daily then you have a problem.
06-28-2012 05:06 AM
As of now the fales carrier errors are 539...
Is it make any problem?.. if i want fix the problem what i need to do?
Transmit Receive
945130476 Bytes 704286385 Bytes
4627987 Frames 2896862 Frames
493692 Multicast frames 0 FCS errors
310672 Broadcast frames 24905 Multicast frames
0 Pause frames 5318 Broadcast frames
0 Total collisions 539 False carrier errors
1496870 Minimum size frames
2061206 65 to 127 byte frames
813245 128 to 255 byte frames
225429 256 to 511 byte frames
261930 512 to 1023 byte frames
2711638 1024 to 1518 byte frames
06-28-2012 10:35 AM
1) Is there a problem from a end user perspective?
2) Can you move it to a diff port to see if problem stays on port or cable
3) If problem follows cable, on the remote device can you move port to see if problem stays with port or cable.
4) I believe problem will be with cable, if so, new cabling (or ends).
06-28-2012 04:45 PM
Dude,
Let's settle this once and for all.
How important is this client connected to this port? If it's that important, GET A TDR TEST DONE!
06-28-2012 10:04 PM
For the OP:
How to use Time-Domain Reflectometer (TDR)
https://supportforums.cisco.com/docs/DOC-18983
Post results.
