Community Member
crc errors on uplink ports to our Nexus 7000
we have several uplink ports on a verity of cisco switches connecting to the nexus 7000, recording CRC errors.
most are trunked ports with the following configuration.
access switch:
interface GigabitEthernet0/25
switchport mode trunk
switchport nonegotiate
end
nexus port:
interface Ethernet1/19
switchport
no shutdown.
nexus is running:
version 5.2(1)
switch is running:
ws-c3560G-24TS    12.2(35)SE5
do not see any performance issues, just crc errors.  Any ideas?
Everyone's tags (4)
What type of module is in the N7K? Can you tell us if the problem is on 1 module or across multiple? Do the errors also show up as input errors?
Dale
Community Member
Re: crc errors on uplink ports to our Nexus 7000
modules:
48 port 1000 Mbps Optical Ethernet Module  N&K-M148GS-11
it is happening over two modules we have.
Nexus 7K Mod  Ports  Module-Type                        Model              Status ---  -----  ----------------------------------- ------------------ ----------
1    48    1000 Mbps Optical Ethernet Module  N7K-M148GS-11      ok
2    8      10 Gbps Ethernet XL Module          N7K-M108X2-12L    ok
3    48    10/100/1000 Mbps Ethernet Module    N7K-M148GT-11      ok
5    0      Supervisor module-1X                N7K-SUP1          active *
6    0      Supervisor module-1X                N7K-SUP1          ha-standby
8    48    10/100/1000 Mbps Ethernet Module    N7K-M148GT-11      ok
9    8      10 Gbps Ethernet XL Module          N7K-M108X2-12L    ok
10  48    1000 Mbps Optical Ethernet Module  N7K-M148GS-11      ok
example of access switch uplink port:
GigabitEthernet0/25 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 3cdf.1ec7.f999 (bia 3cdf.1ec7.f999)   MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,     reliability 255/255, txload 1/255, rxload 20/255   Encapsulation ARPA, loopback not set   Keepalive not set   Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP   input flow-control is off, output flow-control is unsupported   ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 2d19h   Input queue: 0/75/0/0 (size/max/drops/flushes);
Total output drops: 0   Queueing strategy: fifo   Output queue: 0/40 (size/max)
5 minute input rate 79949000 bits/sec, 7092 packets/sec
5 minute output rate 1975000 bits/sec, 3432 packets/sec
1638438298 packets input, 2268962487134 bytes, 0 no buffer
Received 98383573 broadcasts (0 multicasts)     0 runts, 0 giants, 0 throttles
96602 input errors, 96602 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 62304948 multicast, 0 pause input     0 input packets with dribble condition detected
742062096 packets output, 96087437772 bytes, 0 underruns
2191
