Creating a VLAN
Hello I am working on a project where I have encountered a catlayst switch with the vlans created only using "interface vlan" command
interface Vlan163
no ip address
There is no "vlan [vlan id] " comanad to creat the VLAN , can any body send me a reference for this ?
Thanks in advance
10 Replies 10
Sandeep Choudhary
Hi George,
Use this
Switch# config t
Switch(config)#vlan 163
switch(config-vlan)#vlan name xyz
it will create a vlan
Please rate if it helps.
No this is not my question of course I know how can I creat a vlan ,  the questions is
How do those vlan function and forward traffic when there is no vlan command ??!!
If the switch is layer 3 then this catlayst do the intervlan routing .
Do u know about intervlan routing or ???
This is your question or something else???
If you wanna know abt intervlan config then let me know.
no it does not not do inter valn , as you can see there is no IP address configured under the "interface vlan"
My question is how come when you type "show spanning-tree "  you can see vlan 163 and access and tunk ports for this vlan , when in fact the command "vlan 163"  was not wirtten at all ?
Have got my question
George Monier
CCNP/CCNIP/JNCIP
Can you please post the show Vlan brief or show ip in brief that will enlighten us
unfortunately this is a customer`s that I do not admin , and getting this is not that easy but I am trying to do so . But for now can we really do so ? ( mean creat a vlan without a vlan command)  ?
vann_will
Hey George
It could be possible that they were using those vlan's as Layer 2 Traffic only and not Layer 3.
Hope this helps
Hello Vann_will
                           Indeed it is a L2 VLAN , and this is the point "could you have a L2 vlan by only using the interface vlan command"
George Monier
CCNP/CCNIP/JNCIP
Hey George
Normally when I create a L2 Vlan, I used the commands below:
conf t
vlan XXX
name Test
end
wr
But if you do the command sh vlan and you see these vlan's active then I guess you can create L2 Vlan using the commands below:
conf t
int vlan XXX
no ip address
end
wr
sh vlan
Hope this helps
mahmoodmkl
Level 7
Level 7
Try this.
switch#vlan database
switch(vlan)#vlan 2
