01-31-2008 06:59 AM - edited 03-05-2019 08:51 PM
According to the CAT6xxx 8.x configuration guide, when creating a new trunk (set trunk) all vlans are added by default. Use the clear trunk command to prune any vlans you don't want on the trunk. The configuration example has the clear trunk command listed before the set trunk command which strikes me as illogical. How can you clear a trunk before you create a trunk?
01-31-2008 07:02 AM
That's the order CatOS list the commands after entering into the config. You can configure the trunk first and then clear it but if you issue a show run, you will see the clear goes before the set :)
__
Edison.
01-31-2008 07:15 AM
Is there a reason why the clear command would appear before the set command in the running config?
01-31-2008 07:35 AM
CatOS does many things with no logical reason. The more you spend time with it, the more you will understand what I mean :)
I believe it's done alphabetically.
__
Edison.
01-31-2008 08:39 AM
Thanks for your timely replies and insight. I don't think it will settle the debate here at work but at least we some clarification. Hope the question doesn't come up in an exam :)
01-31-2008 08:48 AM
I hope so too. Cheers
01-31-2008 09:27 AM
No worries, I don't believe CatOS is tested any longer on any Cisco Certification Exam :)
__
Edison.
