Webcast-Catalyst9k
Cron Job on Cisco IOS Router?
I would like to know if it is possible to schedule jobs on a cisco router which execute certain commands on certain times.
Thanks!
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Cron Job on Cisco IOS Router?
"You can only use privileged-mode commands with kron; it doesn't allow any Global or Interface configuration commands. This is because it executes each command separately."
Purple
kron can do some of that . Not sure what you have to have for code , think it is at least 12.4 code .
Bronze
The IOS can schedule commands. Here is a nice article detailing how to do that:
http://articles.techrepublic.com.com/5100-10878_11-5553313.html
I've made the following kron job, but it doesnt function. Can anyone tell me why? This is just a test, but this should work right?
kron occurrence test at 12:21 recurring
policy-list TEST
kron policy-list TEST
cli enable
cli config terminal
cli int lo 500
cli ip add 9.9.9.9 255.255.255.255
cli exit
Your answer lies in the "Know your limitations" sections of the above URL provided by Bret.
Thanks for the rating.
10005
