cross-stacked switches/etherchannel with ASA
Dears,
I'm trying to configure a cross-stack etherchannel between two physical switches 2960-X and one ASA 5512-X
Here is the switches configuration:
Switch1(config)# interface range interface gigabitEthernet 1/0/1-2 (connected to ASA port 3 and 4)
Switch1(config-if-range)# switchport mode trunk
Switch1(config-if-range)# channel-group 1 mode on
Switch1(config-if-range)# end
Switch2(config)# interface range interface gigabitEthernet 2/0/1-2 (connected to ASA port 5 and 6)
Switch2(config-if-range)# switchport mode trunk
Switch2(config-if-range)# channel-group 1 mode on
Switch2(config-if-range)# end
ASA configuration
nterface GigabitEthernet0/2
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
no nameif
no security-level
no ip address
Some interfaces are in suspended mode
show port-channel summary
Number of channel-groups in use: 1
Group Port-channel Protocol Ports
1 Po1(U) LACP Gi1/0/1(P) Gi1/0/2(P) Gi2/0/1(s) Gi2/0/2(s)
I don't know how to get all ports in P mode instead of (s) suspended.
Can we create only a port channel nb 1 on the ASA with 4 interfaces and a port channel nb1  on both switches with Gi1/0/1-2, Gi2/0/1-2.
Should we create two port channels on the ASA and switches?
Is there any workaround with VSS?
Everyone's tags (1)
116
