Community Member
CRS to CRS basic Connectivity Issue
I have a very basic CRS connectivity issue.
CRS_R2-----Fiber Connectivity----ME_3400---Fiber Connectivity------CRS_R3
I had some basic connectivuty issue when i try to connect
the 2 CRS (R2-R3 ) point to point via ME-3400 switch. The problem is happening when i am trying to connect one
CRS to other ; else the same interface of CRS if connected to a normal router like R6,R7,R8 works fine. I am using the CRS for the first time
so thought if there is some special config u need to do to be able to ping.
I am pasting my relevant config below . Can you please help?
R2 - CRS
interface GigabitEthernet0/4/0/0.23
ipv4 address
ipv6 address 2002:9:9:23::2/64
dot1q vlan 12
interface GigabitEthernet0/4/0/0.25
ipv4 address
ipv6 address 2002:9:9:25::2/64
dot1q vlan 11
R3 - CRS
interface GigabitEthernet0/7/0/0.23
ipv4 address
dot1q vlan 12
interface GigabitEthernet0/7/0/0.34
ipv4 address
dot1q vlan 14
interface GigabitEthernet0/7/0/0.37
ipv4 address
dot1q vlan 15
vlan 11-14,16-19,21,37,78,101,106,108-109,112-114,121,123,128,143,146,156
vlan 157,178-179,189,197,200-205
interface GigabitEthernet0/2
description Interface connected to interface GigabitEthernet0/4/0/0 of R2
switchport trunk allowed vlan 11,12
switchport mode trunk
media-type sfp
interface GigabitEthernet0/3
description Interface connected to interface GigabitEthernet0/7/0/0 of R3
switchport trunk allowed vlan 12,14,15,17,22,101
media-type sfp
From R2 i am trying to ping,
Ping which is unsuccessful
The other subinterfaces you see on R2 and R3 are connected to normal 7200/3700 routers and the connectivity works fine.
