Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CSCsx29696 - percentSUPQ-4-CPUHB_RECV_STARVE - receive queue stuck after throttling on 2960
Hello, I have a problem with Cisco Catalyst 2960 with IOS ver 12.2 (35)SE5.
4 years ago we purchased 10 Cisco Catalyst 2960 with IOS ver 12.2 (35)SE5 and now operating them.
After 4 years of normal working one of Cisco Catalyst 2960 became bad. After switching 2 computers to any FastEthernet interfaces in the console I see:
%SUPQ-4-CPUHB_RECV_STARVE: Still seeing receive queue stuck after throttling
%SUPQ-4-CPUHB_SLOW_TRANSMIT: CPU Heartbeat Tx buffer not returned
I tried to upgrade the IOS on the following: IOS Release 12.2(53)SE1, IOS Release 12.2(55)SE, IOS Release 12.2(55)SE9  but where was NO EFFECT.
Please, tell me what shell I do to fix this problem.
Thank you.
Technical engineer, Tischenko Kirill.
1 REPLY
Hello Tischenko,
Hello Tischenko,
Trust you are doing great.
Have you tried configuring the workaround mentioned in the Bug CSCed03214
<b>Workaround:</b>
1) Configure the interface for full-duplex instead of half-duplex.
2) Find the interface that is receiving 1-byte frames and correct the wiring and/or
problem on the connected device.
<b>Additional Information:</b>
To find the interface that is receiving 1-byte frames, use the command <b>show platform
port-asic receive port-lockup</b>.
If an interface is configured for 10Mbps half-duplex, but shows non-zero and incrementing
<b>ifix</b> counters, reconfigure the interface and connected device for 10 Mbps
full-duplex, or 100Mbps or 1000Mbps (any duplex).
If an interface is configured for 10Mbps full-duplex, 100Mbps or 1000Mbps (any duplex),
but shows non-zero and incrementing <b>ifix</b> counters, the connected interface
or wiring is likely the cause of the 1-byte frames.
Mohit
** Please rate if the post is helpfull
561
