Switching
Get 20% off switches when you combine Cisco solutions
Labels
I am verifying an inventory for a client for which my company is upgrading the network equipment. I have a few serial numbers without the model number on my inventory and wanted to know how I can look up a device and get the model number. I do not ha...
I'm struggling to understand connectivity problem between a switch and firewall.  The Nexus is located between the Core switch and the edge firewall. It's purpose is to divert traffic via ITD for content filtering.  My problem right now is that I'm n...
jeff20 by Level 1
  • 392 Views
  • 25 replies
Recently I've seen some switches show ports with a status of "notconnect:"  What does the colon at the end signify?I don't have it documented where all I've seen it but I just now saw it on a 6 stack of WS-C3650-48PD running 16.12.06. About 85% of ou...
stonent01 by Level 1
  • 617 Views
  • 6 replies
Hello Professionals,I setup the NTP server in one of branch site and would like to make all network switches to see this server including other branches. - NTP server: 10.10.10.158 (placed in CST timezone, it refers pool.ntp.org) - NTP Client: Switch...
eeebbunee by Level 1
  • 106 Views
  • 3 replies
Hello together, I want to upgrade to a Cisco Catalyst 9500. I enter the following command:install add file bootflash:cat9k_iosxe.16.09.04.SPA.bin activate commit The following line I confirm with Yes:Please confirm you have changed boot config to boo...
Dear all,I've set manually a specific port, in which have a non-Cisco WiFi 6 Access Point running, to provide 30W to make the PoE+ runs, but the AP itself didn't recgonize the power provided as PoE+.I've adjusted at web interface as well at CLI. Is t...
jobe83 by Level 1
  • 148 Views
  • 4 replies
So, previously I had a static IP address I could point putty at that would SSH just fine. I verified the address in a Show Run form I copied two days ago, so I'm not crazy. The config was written to memory multiple times so it's not that. Today, afte...
kenohol by Level 1
  • 102 Views
  • 2 replies
Hi, I have three CBS220-48P-4G-SW1 configured with LAG uplink consisting of two port between each of those switches.When I try to enable LACP on those LAG I get an error code 387.Does anybody got this issue and figured how to resolve it ?
slefebvre by Level 1
  • 55 Views
  • 0 replies
Hello,I have a cisco router connected to ISP using Dialer interface. I can access the web no problem, but have problems configuring port forwarding to a local computer from outside. Trying with tcp port 5555.Any idea what I am doing wrong? Thanksvers...
maple1 by Level 1
  • 86 Views
  • 4 replies
So, previously I had a static IP address I could point putty at that would SSH just fine. I verified the address in a Show Run form I copied two days ago, so I'm not crazy. The config was written to memory multiple times so it's not that.Today, after...
dxtrgerry by Level 1
  • 61 Views
  • 2 replies
Switch A, Cisco 9300, VTP mode transparentinterface GigabitEthernet1/0/5switchport access vlan 3switchport mode accessSwitch B, Cisco 3560, VTP mode transparentinterface GigabitEthernet1/0/1switchport access vlan 3switchport mode accessVlan 3 (L2) vl...
I have a strange one. C9200 switch, 17.03.04b. Setting up a port for a postage machine. config as follows:ip dhcp pool cin-6address 10.3.6.2 client-id 0100.1b00.4116.4dinterface GigabitEthernet1/0/15description Postage machineswitchport access vlan 6...
geocoles by Level 1
  • 48 Views
  • 1 replies
Hi,I have been testing MST in my lab which has 3x Cisco Catalyst WS-C2960CG-8TC-L switches.I configured only MST and LACP on each switch and connected them in the ring topology. Test is to see how much time it takes for convergence in such conditions...
