12-14-2007 09:23 AM - edited 03-05-2019 08:00 PM
All, Im curious as to why, when you upgrade an IOS on a router or switch using TFTP, sometimes the exclamation points, during the tftp process, goes fast, and sometimes it goes slow. Why is that?
12-14-2007 10:07 AM
The donwload is slow which could be for many reasons, but one thing you can check is make sure you don't have any mismatch in terms of half/full duplex on the link.
++jose
12-14-2007 10:26 AM
Yeah, thought about that, but had this on the same router. Did the first upload and it went really quick. Decided to put a different IOS on and it went really slow the second time. Its a gig port, and I have a little home switch that does auto-negotiation. Router set to auto as well. Hmm. Not sure.
12-14-2007 10:28 AM
good thing you're not a cat...
check your link speeds. that is most likely the issue, unless you had a bunch of other traffic going on during the slow IOS tftp.
-brad
(please rate the post if this helps!)
