Custom queueing
Recently I performed a workbook lab with a question about custom queueing. The question was to give a percentage bandwidth to 4 types of traffice
20% FTP (1500bytes)
30% HTTP (600bytes)
40% UDP5001 (300 bytes)
10% all that is left
The bandwidth is devided by byte-count. But is this number meaning anything? I think its just a number you can take and devide it into percentages
queue-list 1 protocol ip 1 tcp ftp
queue-list 1 protocol ip 1 tcp ftp-data
queue-list 1 protocol ip 2 tcp www
queue-list 1 protocol ip 3 udp 5001
queue-list 1 default 4
Will both byte-count option do the same?
queue-list 1 queue 1 byte-count 3000
queue-list 1 queue 2 byte-count 4500
queue-list 1 queue 3 byte-count 6000
queue-list 1 queue 4 byte-count 1500
or
queue-list 1 queue 1 byte-count 200
queue-list 1 queue 2 byte-count 300
queue-list 1 queue 3 byte-count 400
queue-list 1 queue 4 byte-count 100
Giuseppe Larosa
Hello Maarten,
custom queueing is a legacy queueing scheduler where packet sizes and byte counts really counts for resources allocation
Clearly in current IOS routers everyone would use CBWFQ instead
see
http://www.cisco.com/en/US/docs/ios/12_0/qos/configuration/guide/qccq.html
generally calculations need to be performed with an iterative process
byte count should be big enough to accomodate a packet of size  = MTU on outgoing interface so it is better to use higher byte counts but not too big to avoid to increase jitter of packets waiting in the othe queues
at each round from each queue up to byte count bytes can be taken
custom queueing will take one or more packets causing distortion of BW distribution for this reason average packet size plays a role in the formula
that is if byte count is 501 and the packets are of size 500 bytes two packets are taken from the queue.
I may be wrong but I don't think that custom queueing is still part of current exams including CCIE level
Hope to help
Giuseppe
