11-16-2011 03:44 PM - edited 03-07-2019 03:26 AM
Forum
I have a customer whom is requesting to see quotes for either a 12 port or 16 port Cisco switch. The switch must do 10/100/1000 on each of its ports, and have the ability to do SFP uplinks.
I have searched the Cisco Web, and have also contacted Partner support. Both efforts have proven futile.
I am able to find 10/100 switches in the SMB line and in the Enterprise line.
Does anyone know of a managed switch that will do SFP uplink, POE, 10/100/1000 that comes in port density 12 or 16?
Thanks in advance!
Kevin
Solved! Go to Solution.
11-16-2011 04:21 PM
Oops! Missed the 1Gb requirement.
The answer is: There's no 12- or 16port 1Gb switch with SFP. The cheapest is either the 2960S-24TS or 3560G-24TS.
Not sure about Linksys product.
11-16-2011 03:51 PM
How many?
Look at this: WS-C3560-12PC
There is no 16-port switch unless you are planning to purchase a network module for a router.
11-16-2011 04:07 PM
11-16-2011 04:21 PM
11-16-2011 05:12 PM
Thanks for verifying what I thought must be the correct answer after relentless searching!
11-16-2011 05:38 PM
Thanks for the ratings Kevin.
11-16-2011 05:40 PM
As an alternative to a general cisco.com search, have a look at the Cisco Product Quick Reference Guide. It's updated pretty regularly and is a good one-place overview of the various products.
http://www.cisco.com/en/US/customer/prod/qrg/index.html
Hope this helps.
