02-10-2008 01:14 PM - edited 03-05-2019 09:03 PM
I have 5 48-port 2960 switches (50 counting the 2 GB ports). I want to uplink them on the GB ports.
Is there a daisy chain limit on switches like there is on hubs?
Denny
Solved! Go to Solution.
02-10-2008 03:20 PM
No hard limit, but you want to maximize the uplink ports so I suggest the attached layout.
The green links are traffic being forwarded towards the root. The red link indicate port being blocked in order to avoid a SPT loop.
HTH,
__
Edison.
02-10-2008 03:12 PM
Denny, I do not believe you can daisy chain 2960 switches, instead you may use clustering technology to accomplish what you need, you could have up to 16 devices in a switch cluster.
Switch Clusterining
Rgds
Jorge
02-10-2008 03:20 PM
02-10-2008 04:54 PM
No, not like hubs.
If using spanning tree based on the STP 802.1D standard, you're not supposed to have, I believe, more than 7 hops. (That's for worst case performance and hopefully you would use a newer spanning tree standard, e.g. RSTP 802.1W.)
02-10-2008 05:49 PM
Hi Joseph,
Out of curiosity, any particular reasons why is it 7 hops? Thank you.
02-10-2008 05:54 PM
Something to do with timing dependencies, I believe.
