01-07-2014 08:37 PM - edited 03-07-2019 05:26 PM
hi all,
just a quick question, can the below config be converted on a cisco switch port.
INITIAL CONFIG:
interface FastEthernet0/1
switchport trunk native vlan 2
switchport mode trunk
switchport voice vlan 1
no mdix auto
spanning-tree portfast
CONVERT TO:
switchport access vlan 2
switchport mode access
no mdix auto
Solved! Go to Solution.
01-08-2014 05:24 AM
I don't see why not.
01-08-2014 09:28 AM
Yes that is how we setup our ports:
interface FastEthernet0/3
switchport access vlan 10
switchport voice vlan 20
switchport port-security maximum 2
switchport port-security maximum 1 vlan access
switchport port-security aging time 1
switchport port-security violation restrict
switchport port-security aging type inactivity
no logging event link-status
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust cos
auto qos trust
01-08-2014 01:13 PM
Hi, Yes you can use this configuration to connect your workstation(DATA) to switch via IP phone(voice).
In this configuration the workstation would utilize the data vlan and the IP phone would utilize the data vlan first and then the voice vlan.
Thanks.
01-08-2014 05:24 AM
01-08-2014 09:28 AM
priority-queue out
mls qos trust cos
auto qos trust
01-08-2014 01:13 PM
Thanks.
01-08-2014 01:26 PM
Apart from the answer "yes" to your question:
it is not custom to use vlan 1 as voice vlan
Vlan 1 is default used for many other packets too
01-08-2014 06:02 PM
thank you guys for your feedback! +5
i just wanted to confirm before i go and make changes (although deep in my head i already know).
pieterh,
yes, from a security standpoint i understand. but the network is already in place (a long time ago) and it would be a major change just to change VLAN 1.
01-08-2014 06:11 PM
no mdix auto
It will work, John but I question the "sanity" of this line.
I do not see the benefits gained by disabling MDI/MDI-X.
01-08-2014 09:37 PM
thanks pre for spotting this!
good stuff! (as what my australian boss tells me).
maybe i can enable mdix back.
i'm not sure why the previous admin did this.
