Data Traffic Path
rwamstutz
I have replication going from 1 device to another. The path is Device --> Switch --> Router --> Switch --> Device.
On the return, the device is sending: Device -->Switch --> Switch --> Device.
How does this affect traffic? Does it slow it down because its going a different way than what it was recieved?
Jon Marshall
Is device 1 on a different vlan than device 2 and if so if one of the Switches a layer 3 switch.
Jon
Different VLANS, but switches are 3750
Amit Singh
Rob,
If the traffic is indeed coming the same way back then you would definately see some performance slow down as it will be asymmetric routing process. this will slow down the traffic process a little bit as the return traffic is not taking the same patch to the client.
http://danno.appliedi.net/drupal/?q=node/101
HTH,Please rate if it does.
-amit singh
amit, do you mean if the traffic is taking a differnet way back?
