%DATACORRUPTION-1-DATAINCONSISTENCY:
Hi Netpro,
anyone know how to fix this ? this log show on my Core-Switch 6509-E
Sep 8 17:01:40.662 CCT: %DATACORRUPTION-1-DATAINCONSISTENCY: copy error, -PC= 0x40D24290
-Traceback= 4043FB00 4045C420 40D24290 40D21564 4045FAF4 41056218 4046DFD8 4103DE88 4103DE74
thanks a lot.
Re: %DATACORRUPTION-1-DATAINCONSISTENCY:
Post the show version output from this switch.
Hi Jclarke,
As requested,
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF12, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Sun 18-Nov-07 06:39 by kellythw
Image text-base: 0x40101040, data-base: 0x42DCC630
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF12, RELEASE SOFTWARE (fc2)
CS_2_1 uptime is 11 weeks, 2 days, 9 hours, 49 minutes
Time since CS_2_1 switched to active is 11 weeks, 2 days, 9 hours, 48 minutes
System returned to ROM by power cycle at 00:13:47 UTC Thu Jun 26 2008 (SP by power on)
System restarted at 01:58:42 CCT Mon Jun 22 2009
System image file is "sup-bootdisk:s72033-ipservicesk9-mz.122-18.SXF12.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.4) with 458720K/65536K bytes of memory.
Processor board ID SMC1222001W
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
87 Virtual Ethernet/IEEE 802.3 interfaces
74 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
This looks like CSCso85695. It's not fixed on the 6500 until 12.2(33)SXH4.
Hi Jclarke.
appreciate if you could post the output from the bug toolkit.
coz, i have limited access with limited information :(
CSCso85695 Bug Details
Information contained within bug ID CSCso85695 is only available to Cisco employees. It is our policy to make all externally-facing bugs available in Bug Toolkit so the system administrators have been automatically alerted to the problem. By choosing to save this bug, you may be notified when the decision to make this bug available to you has been made. Note: Some product enhancement requests and documentation error bugs may not be available in Bug Toolkit.
Unfortunately, there are not a lot of details I can share about this bug. I can say that is triggered by RMON data querying either by SNMP or through the CLI (e.g. the "show rmon events" command).
Hi Jclarke,
Thanks for your information.
but what is the corrective action should i need to take to resolve this problem ?
thanks a lot.
According to the detail in the bug, the only solution is an upgrade. No other workarounds are offered. Of course, if you avoid using RMON with the switch, then this crash should not occur.
Hi Jclarke.
Noted with thanks.
Jack
2410
