07-13-2007 04:34 AM - edited 03-05-2019 05:17 PM
One 6509 suffers a power failure in module 3.And the error message is "%OIR-6-PWRFAILURE: Module 3 is being disabled due to power convertor failure
This message indicates that the DC-DC power convertor failed on the specified module."
Cisco's suggestion is " You need to replace hardware. "
I want to know if there is any other solutions for such problem.
Thanks!
Solved! Go to Solution.
07-13-2007 07:09 AM
I hope that you are NOT looking forward fora Power Supply Module for 6509 which is from some vendor who is not Cisco?
You can simply place an order for a new Power Supply module by looking at the Part Number and talking to your local Cisco Partner
Regards.
Wilson Samuel
07-13-2007 07:09 AM
Regards.
Wilson Samuel
07-14-2007 04:17 AM
Hi,Wilson
It's really helpful.Thanks
Freedream
