Community Member
DC-DC power convertor failure
One 6509 suffers a power failure in module 3.And the error message is "%OIR-6-PWRFAILURE: Module 3 is being disabled due to power convertor failure
This message indicates that the DC-DC power convertor failed on the specified module."
Cisco's suggestion is " You need to replace hardware. "
I want to know if there is any other solutions for such problem.
Thanks!
1 ACCEPTED SOLUTION
Re: DC-DC power convertor failure
I hope that you are NOT looking forward fora Power Supply Module for 6509 which is from some vendor who is not Cisco?
You can simply place an order for a new Power Supply module by looking at the Part Number and talking to your local Cisco Partner
Regards.
Wilson Samuel
Regards.
Wilson Samuel
Community Member
Hi,Wilson
It's really helpful.Thanks
Freedream
386
