dCef on 6500 line cards
I have the following in my 6509.
Mod Ports Card Type Model Serial No.
1 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL2007DUVM
2 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL28311C2M
3 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL20425ER7
4 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAD29010DW6
6 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL2015JVRR
Mod MAC addresses Hw Fw Sw Status
1 0016.c7a1.6c04 to 0016.c7a1.6c1b 2.3 12.2(14r)S5 12.2(18)SXD7 Ok
2 0001.0002.0003 to 0001.0002.0032 2.0 12.2(14r)S5 12.2(18)SXD7 Ok
3 0019.56c3.ec80 to 0019.56c3.ecaf 2.5 12.2(14r)S5 12.2(18)SXD7 Ok
4 0011.bb2b.6590 to 0011.bb2b.65bf 2.5 12.2(14r)S5 12.2(18)SXD7 Ok
6 0017.5a35.00e0 to 0017.5a35.00e3 5.2 8.5(2) 12.2(18)SXD7 Ok
Mod Sub-Module Model Serial Hw Status
1 Centralized Forwarding Card WS-F6700-CFC SAL1051BPBD 3.1 Ok
2 Distributed Forwarding Card WS-F6700-DFC3B SAD0951031D 4.2 Ok
3 Distributed Forwarding Card WS-F6700-DFC3B SAL1006CXXM 4.2 Ok
4 Distributed Forwarding Card WS-F6700-DFC3B SAD0951030D 4.2 Ok
6 Policy Feature Card 3 WS-F6K-PFC3B SAL1015JMMM 2.3 Ok
6 MSFC3 Daughterboard WS-SUP720 SAL1015JMXX 2.6 Ok
Its states that distributed forwarding is enabled by default on 6500 but when I do:
#show cef interface gigabitEthernet 3/1
GigabitEthernet3/1 is up (if_number 272)
Corresponding hwidb fast_if_number 272
Corresponding hwidb firstsw->if_number 272
Internet Protocol processing disabled
Hardware idb is GigabitEthernet3/1 (272)
Software idb is GigabitEthernet3/1 (272)
Fast switching type 22, interface type 142
IP CEF switching enabled
IP Fast switching turbo vector
IP Normal CEF switching turbo vector
Input fast flags 0x0, Output fast flags 0x0
ifindex 269(269)
Slot 3 Slot unit 1 VC -1
Transmit limit accumulator 0x0 (0x0)
IP MTU 1500
How do I enabled dCef for my 3 6748 line cards and keep normal Cef on the 6724?
1 ACCEPTED SOLUTION
Blue
Re: dCef on 6500 line cards
Joseph:
He does have dCEF cards installed.
Mr. Noobie:
Enter the ip cef distributed command in global config mode.
If so, kindly rate this post
Victor
Super Bronze
I believe dCEF is dependent on whether there's a DFC installed on the line card.
Blue
Joseph:
Mr. Noobie:
Victor
Super Bronze
Victor, thank you.
Blue
Joseph:
You got it, buddy...
Thanks for response, before I enable "ip cef distributed", will I lose connectivity and will my 6724 that does not have DFC card still work properly?
Blue
The short answers are no and yes, respectively.
If you're worried, set up a window and do it then.
No biggie.
Please rate my posts if they helped you
629
