07-08-2012 02:48 PM - edited 03-07-2019 07:39 AM
i have several cisco 3500XL switches with trunking. I created a VLAN lets say 20 which purpose is for wireless clients. I installed wireless controller with 4 APs and controllers sees all 4 APs. Controller is also DCHP server. When wireless client authenticates it's DCHP requests in not getting to DHCP server (controller). If i connect all equipment in non managed switch everything works. What could be the problem? Thanks!
07-08-2012 04:53 PM
Can you post the switch config
Are the APs connected to the switch via trunks?
07-08-2012 11:18 PM
AP's are connected over trunk ports, i am not currently at the locaiton wher switches are but what i did is this:
conf t
interface gigabitethernet 0/12
switchport access vlan 20
spanning-tree portfast
no shut
exit
exit
write memory
Ports are configured like that and vlan is allowed over trunk also. Aside from that i didn't make any other changes. Thx!
07-09-2012 01:59 AM
Is the DHCP server in another VLAN ? if so then you'll have to use ip helper-address x.x.x.x under the SVI where x.x.x.x is the ip address of dhcp server.Also make sure dhcp service is enabled for the relay: service dhcp command
Regards.
Alain.
07-09-2012 02:00 AM
DHCP server is inside same VLAN that is what is confusing me why this isn't working.
07-09-2012 02:04 AM
Could you post the config from switch where AP is not getting IP as well as a diagram of your network.
Regards.
Alain.
07-09-2012 02:09 AM
AP gets the IP from the wireless controller, but wireless client that authenticates on AP isn't getting IP. Hmm maybe problem lies inside wireless controller since it has ability to have multiple virutal SIDS on it. Could be that they also have their own VLAN that i have to pass over switch imo.
07-09-2012 04:23 AM
conf t
no shut
exit
exit
write memory
Hello ,
Is WLC interface is configued with trunk allwoing the AP vla, if not then ishoudl be allowed ...check for WLC interfaces for trunk conguration.
Hope to Help !!
---Ganesh
07-09-2012 04:28 AM
Unfortunatley it's Sonicwall WLC and sonicwall APs , will have to check the configuration on it.
EDIT:
In case someone faces same problem.
http://www.fuzeqna.com/sonicwallkb/consumer/kbdetail.asp?kbid=5133
07-09-2012 11:52 AM
SCC_Sanctuary#sh run
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname SCC_Sanctuary
enable password 7 112A1016141D
username global privilege 15 password 7 045C5A560D201D0D2A2D54
username stockdale privilege 15 password 7 113A0D0A14195A5F51
ip subnet-zero
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
switchport mode trunk
switchport voice vlan 10
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface VLAN1
ip address 10.0.0.246 255.255.255.0
no ip directed-broadcast
no ip route-cache
ip default-gateway 10.0.0.254
snmp-server engineID local 0000000902000007EB81D240
snmp-server community private RW
snmp-server community public RO
line con 0
transport input none
stopbits 1
line vty 0 4
login local
line vty 5 15
login local
end
SCC_Core# sh run
Current configuration : 1856 bytes
version 12.1
no service pad
hostname SCC_Core
enable password 7 0802455D0A16
username global privilege 15 password 7 06015E714E4F585A262343
username stockdale privilege 15 password 7 097F5A061A0E46415E
ip subnet-zero
ip routing
spanning-tree mode pvst
no ip address
no ip address
interface GigabitEthernet0/3
switchport mode dynamic desirable
no ip address
interface GigabitEthernet0/4
no ip address
interface GigabitEthernet0/5
no ip address
interface GigabitEthernet0/6
no ip address
interface GigabitEthernet0/7
no ip address
interface GigabitEthernet0/8
no ip address
interface GigabitEthernet0/9
no ip address
interface GigabitEthernet0/10
no ip address
interface GigabitEthernet0/11
no ip address
interface GigabitEthernet0/12
switchport mode access
no ip address
interface Vlan1
ip address 10.0.0.253 255.255.255.0
interface Vlan10
no ip address
ip helper-address 10.0.0.11
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.254
ip http server
snmp-server community scc RO
line con 0
line vty 0 4
login local
line vty 5 15
login local
end
WLC is connected to Core, AP is on other switch. VLAN 20 is wireless VLAN.
EDIT: i tried plugging laptop on the port where AP is and it didn't get the IP even though DHCP server is running inside VLAN 20. Now i am confused...
07-09-2012 11:36 PM
This is solution:
Looks like sonicwall uses several VLANs..
